[postgis-tickets] r15257 - Prep for 2.2.4 release
Regina Obe
lr at pcorp.us
Sat Nov 26 13:19:59 PST 2016
Author: robe
Date: 2016-11-26 13:19:58 -0800 (Sat, 26 Nov 2016)
New Revision: 15257
branches/2.2/ChangeLog
branches/2.2/NEWS
branches/2.2/README.postgis
branches/2.2/Version.config
branches/2.2/doc/release_notes.xml
Modified: branches/2.2/ChangeLog
--- branches/2.2/ChangeLog 2016-11-26 19:54:38 UTC (rev 15256)
+++ branches/2.2/ChangeLog 2016-11-26 21:19:58 UTC (rev 15257)
@@ -1,3 +1,77 @@
+2016-11-26 18:54 Regina Obe <lr at pcorp.us>
+ * [r15254] NEWS, raster/rt_pg/rtpostgis.sql.in: add raster
+ constraint max extent exceeds array size limit
+ closes #3501 for 2.2.4
+2016-11-26 15:20 Regina Obe <lr at pcorp.us>
+ * [r15251] doc/reference_measure.xml: ST_Equals documentation does
+ not describe current behavior
+ closes #3566 for 2.2.4
+2016-11-26 15:00 Regina Obe <lr at pcorp.us>
+ * [r15248] doc/extras_topology.xml: Incorrect parameter name for
+ CreateTopology
+ closes #3509 for 2.2.4
+2016-10-31 15:35 Regina Obe <lr at pcorp.us>
+ * [r15221] NEWS, postgis/postgis.sql.in: st_concavehull() returns
+ sometimes empty geometry collection
+ closes #1973 for PostGIS 2.2
+2016-10-28 15:41 Sandro Santilli <strk at keybit.net>
+ * [r15217] .drone.yml: Update drone yml to 0.5 version
+ See https://git.osgeo.org/gogs/sac/gogs-service/issues/14
+2016-10-16 05:36 Regina Obe <lr at pcorp.us>
+ * [r15210] NEWS, raster/rt_pg/rtpostgis.c: raster GUC -
+ boot_postgis_gdal_enabled_drivers should use TopMemoryContext
+ instead of CurrentMemoryContext
+ Closes #3659 for 2.2 (PostGIS 2.2.4) patch provided by manaeem
+2016-10-10 20:24 Sandro Santilli <strk at keybit.net>
+ * [r15201] liblwgeom/lwgeom_geos.c: Fix typo in error message about
+ ClipByBox availability
+2016-10-10 19:46 Sandro Santilli <strk at keybit.net>
+ * [r15199] .drone.yml: Be verbose in running tests
+2016-10-08 09:04 Sandro Santilli <strk at keybit.net>
+ * [r15193] .drone.yml, NEWS, postgis/postgis.sql.in,
+ utils/check_all_upgrades.sh: Fix aggregates upgrade
+ Fixes #3656 (aggregate upgrades)
+ Enables automated ugprade testing
+2016-10-06 17:31 Sandro Santilli <strk at keybit.net>
+ * [r15181] doc/doxygen.cfg.in: Remove hard-coded version in Doxygen
+ project name
+2016-10-06 15:53 Regina Obe <lr at pcorp.us>
+ * [r15176] NEWS: last patch fix was missing from news
+2016-10-06 15:34 Regina Obe <lr at pcorp.us>
+ * [r15173] NEWS, Version.config,
+ extensions/upgradeable_versions.mk: bump to 2.2.4dev
+2016-10-06 13:37 Regina Obe <lr at pcorp.us>
+ * [r15171] ChangeLog, NEWS, Version.config, doc/release_notes.xml,
+ extensions/upgradeable_versions.mk: In prep for 2.2.3 release
2016-10-03 20:20 Paul Ramsey <pramsey at cleverelephant.ca>
* [r15167] NEWS, liblwgeom/lwstroke.c: #3652, crash on
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS 2016-11-26 19:54:38 UTC (rev 15256)
+++ branches/2.2/NEWS 2016-11-26 21:19:58 UTC (rev 15257)
@@ -1,5 +1,5 @@
PostGIS 2.2.4
-xxxx/xx/xx
+2016/11/26
* Bug Fixes *
@@ -7,7 +7,7 @@
Fix from gde
- #3656, Fix upgrade of aggregates from 2.2 or lower version
- #3501, add raster constraint max extent exceeds array size limit
- for large tables
+ for large tables, change to use ST_Extent
- #3659, Crash caused by raster GUC define after CREATE EXTENSION
using wrong memory context. (manaeem)
Modified: branches/2.2/README.postgis
--- branches/2.2/README.postgis 2016-11-26 19:54:38 UTC (rev 15256)
+++ branches/2.2/README.postgis 2016-11-26 21:19:58 UTC (rev 15257)
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 2.2.3
-:Date: 2016-XX-XX
+:Version: 2.2.4
+:Date: 2016-11-26
:Website: http://postgis.net
This distribution contains a module which implements GIS simple features, ties
Modified: branches/2.2/Version.config
--- branches/2.2/Version.config 2016-11-26 19:54:38 UTC (rev 15256)
+++ branches/2.2/Version.config 2016-11-26 21:19:58 UTC (rev 15257)
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=2
POSTGIS_MINOR_VERSION=2
-POSTGIS_MICRO_VERSION=4dev
+POSTGIS_MICRO_VERSION=4
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
Modified: branches/2.2/doc/release_notes.xml
--- branches/2.2/doc/release_notes.xml 2016-11-26 19:54:38 UTC (rev 15256)
+++ branches/2.2/doc/release_notes.xml 2016-11-26 21:19:58 UTC (rev 15257)
@@ -3,6 +3,21 @@
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
<sect1>
+ <title>Release 2.2.4</title>
+ <para>Release date: 2016/11/26</para>
+ <para>This is a bug fix and performance improvement release.</para>
+ <simplesect>
+ <title>Bug Fixes and Enhancements</title>
+ <para>1973, st_concavehull() returns sometimes empty geometry collection
+ Fix from gde</para>
+ <para>3656, Fix upgrade of aggregates from 2.2 or lower version</para>
+ <para>3501, add raster constraint max extent exceeds array size limit
+ for large tables, change to use ST_Extent</para>
+ <para>3659, Crash caused by raster GUC define after CREATE EXTENSION
+ using wrong memory context. (manaeem)</para>
+ </simplesect>
+ </sect1>
+ <sect1>
<title>Release 2.2.3</title>
<para>Release date: 2016/10/06</para>
