[postgis-tickets] [PostGIS] #3653: ERROR: could not load library "/usr/lib/postgresql/9.5/lib/rtpostgis-2.2.so": libnetcdf.so.11: cannot map zero-fill pages
trac at osgeo.org
Tue Oct 4 08:51:19 PDT 2016
zero-fill pages
Reporter: reecefowell | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.1
Component: postgis | Version: 2.2.x
Keywords: |
I am using the PostGIS with Hibernate-Spatial for a Java Spring project,
the version output from PostGreSQL is:
"PostgreSQL 9.5.4 on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu
5.4.0-6ubuntu1~16.04.2) 5.4.0 20160609, 64-bit POSTGIS="2.2.1 r14555"
GEOS="3.5.0-CAPI-1.9.0 r4084" PROJ="Rel. 4.9.2, 08 September 2015"
GDAL="GDAL 1.11.3, released 2015/09/16" LIBXML="2.9.3" (...)"
When running tests with Concordion, after the 6th example passes, all
subsequent tests fail.
The error I get is:
2016-10-03 14:07:28.722 INFO 35396 --- [ main]
o.f.c.i.metadatatable.MetaDataTableImpl : Creating Metadata table:
"public"."schema_version"
2016-10-03 14:07:28.738 INFO 35396 --- [ main]
o.f.core.internal.command.DbMigrate : Current version of schema
"public": << Empty Schema >>
o.f.core.internal.command.DbMigrate : Migrating schema "public" to
version 1 - Initial
2016-10-03 14:07:29.703 ERROR 35396 --- [ main]
o.f.core.internal.command.DbMigrate : Migration of schema "public" to
version 1 failed! Changes successfully rolled back.
org.flywaydb.core.internal.dbsupport.FlywaySqlScriptException:
Migration V1__Initial.sql failed
SQL State : XX000
Error Code : 0
Message : ERROR: could not load library
map zero-fill pages
(/Users/reecefowell/Projects/Spring/bvddy/matchmaking-
service/build/resources/main/db/migration/V1__Initial.sql)
Line : 1
Statement : CREATE EXTENSION IF NOT EXISTS Postgis
at
org.flywaydb.core.internal.dbsupport.SqlScript.execute(SqlScript.java:117)
at
org.flywaydb.core.internal.resolver.sql.SqlMigrationExecutor.execute(SqlMigrationExecutor.java:71)
at
org.flywaydb.core.internal.command.DbMigrate$5.doInTransaction(DbMigrate.java:284)
at
org.flywaydb.core.internal.command.DbMigrate$5.doInTransaction(DbMigrate.java:282)
at
org.flywaydb.core.internal.util.jdbc.TransactionTemplate.execute(TransactionTemplate.java:72)
at
org.flywaydb.core.internal.command.DbMigrate.applyMigration(DbMigrate.java:282)
at
org.flywaydb.core.internal.command.DbMigrate.access$800(DbMigrate.java:46)
at
org.flywaydb.core.internal.command.DbMigrate$2.doInTransaction(DbMigrate.java:207)
at
org.flywaydb.core.internal.command.DbMigrate$2.doInTransaction(DbMigrate.java:156)
at
at
org.flywaydb.core.internal.command.DbMigrate.migrate(DbMigrate.java:156)
at org.flywaydb.core.Flyway$1.execute(Flyway.java:1059)
at org.flywaydb.core.Flyway$1.execute(Flyway.java:1006)
at org.flywaydb.core.Flyway.execute(Flyway.java:1418)
at org.flywaydb.core.Flyway.migrate(Flyway.java:1006)
at com.bvddy.util.DatabaseUtil.migrate(DatabaseUtil.java:44)
at com.bvddy.util.DatabaseUtil.cleanAndMigrate(DatabaseUtil.java:19)
at com.bvddy.test.spec.AbstractSpec.setUp(AbstractSpec.java:29)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at
org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
at
org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
at
org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
at
org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
at
org.springframework.test.context.junit4.statements.RunBeforeTestMethodCallbacks.evaluate(RunBeforeTestMethodCallbacks.java:75)
at
org.springframework.test.context.junit4.statements.RunAfterTestMethodCallbacks.evaluate(RunAfterTestMethodCallbacks.java:86)
at
org.springframework.test.context.junit4.statements.RunPrepareTestInstanceCallbacks.evaluate(RunPrepareTestInstanceCallbacks.java:64)
at
org.springframework.test.context.junit4.statements.SpringRepeat.evaluate(SpringRepeat.java:84)
at
org.springframework.test.context.junit4.statements.SpringFailOnTimeout.evaluate(SpringFailOnTimeout.java:87)
at
org.springframework.test.context.junit4.statements.ProfileValueChecker.evaluate(ProfileValueChecker.java:101)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
at
org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
at
org.concordion.integration.junit4.ConcordionRunner.runChild(ConcordionRunner.java:187)
at
org.concordion.integration.junit4.ConcordionRunner.runChild(ConcordionRunner.java:23)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
at
org.springframework.test.context.junit4.statements.RunBeforeTestClassCallbacks.evaluate(RunBeforeTestClassCallbacks.java:61)
at
org.springframework.test.context.junit4.statements.RunAfterTestClassCallbacks.evaluate(RunAfterTestClassCallbacks.java:70)
at
at
org.springframework.test.context.junit4.rules.SpringClassRule$TestContextManagerCacheEvictor.evaluate(SpringClassRule.java:242)
at org.junit.rules.RunRules.evaluate(RunRules.java:20)
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
at
org.concordion.integration.junit4.ConcordionRunner.run(ConcordionRunner.java:146)
at org.junit.runners.Suite.runChild(Suite.java:128)
at org.junit.runners.Suite.runChild(Suite.java:27)
at org.junit.runner.JUnitCore.run(JUnitCore.java:137)
at
com.intellij.junit4.JUnit4IdeaTestRunner.startRunnerWithArgs(JUnit4IdeaTestRunner.java:117)
at
com.intellij.junit4.JUnit4IdeaTestRunner.startRunnerWithArgs(JUnit4IdeaTestRunner.java:42)
at
com.intellij.rt.execution.junit.JUnitStarter.prepareStreamsAndStart(JUnitStarter.java:262)
at
com.intellij.rt.execution.junit.JUnitStarter.main(JUnitStarter.java:84)
at
at
at
com.intellij.rt.execution.application.AppMain.main(AppMain.java:147)
Caused by: org.postgresql.util.PSQLException: ERROR: could not load
at
org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2310)
at
org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:2023)
at
org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:217)
at org.postgresql.jdbc.PgStatement.execute(PgStatement.java:421)
at
org.postgresql.jdbc.PgStatement.executeWithFlags(PgStatement.java:318)
at org.postgresql.jdbc.PgStatement.execute(PgStatement.java:310)
at
org.flywaydb.core.internal.dbsupport.JdbcTemplate.executeStatement(JdbcTemplate.java:238)
at
org.flywaydb.core.internal.dbsupport.SqlScript.execute(SqlScript.java:114)
... 65 more
After this is output on first test that fails, all other tests show that
it could not connect to the database.
My Schema looks looks like this:
CREATE EXTENSION IF NOT EXISTS Postgis;
CREATE TABLE "user" (
id bigint NOT NULL,
first_name varchar NOT NULL,
search_radius int,
latitude double precision,
longitude double precision,
location geography(Point, 4326),
PRIMARY KEY (id)
Each test runs the following to clean the database state:
@Component
public class DatabaseUtil {
@Autowired
private DataSource dataSource;
@Autowired
private Flyway flyway;
public void cleanAndMigrate() {
clean();
migrate();
private void clean() {
try {
dataSource.getConnection();
} catch (SQLException e) {
JdbcTemplate jdbcTemplate = new JdbcTemplate(dataSource);
jdbcTemplate.execute("DROP SCHEMA IF EXISTS public CASCADE");
jdbcTemplate.execute("CREATE SCHEMA public");
private void migrate() {
flyway.migrate();
From what I can tell, it looks like maybe the process of generating the
table spatial_ref_sys could be eating up all memory.
Whatever it is, it seems to kill the postgresql server and cause all tests
to fail. Could this be a memory leak?
My spring setup.
concordion:2.0.2
flyway-core:3.2.1
hibernate-core:5.0.9.Final
hibernate-spatial:5.0.9.Final
Whats strange is that if I paste the following into pgAdmin3 and run
arbitrary SQL over and over by slamming the run button, it doesn't seem to
fail. What could be causing this disparity?
DROP SCHEMA IF EXISTS public CASCADE;
CREATE SCHEMA public;
id bigint NOT NULL,
search_radius int,
PRIMARY KEY (id)
As per the ticket process, I tried to use an earlier version but in Ubuntu
there is no version of PostGIS above or below 2.2. I install the
following:
- postgresql-9.5
- postgresql-9.5-postgis-2.2
- pgadmin3
- postgresql-contrib-9.5
- python-psycopg2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3653>
