[postgis-tickets] [PostGIS] #3653: ERROR: could not load library "/usr/lib/postgresql/9.5/lib/rtpostgis-2.2.so": libnetcdf.so.11: cannot map zero-fill pages
trac at osgeo.org
Thu Oct 6 10:40:40 PDT 2016
zero-fill pages
Reporter: reecefowell | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.1
Component: postgis | Version: 2.2.x
Resolution: | Keywords:
Comment (by robe):
oh boy, this is a tough one to troubleshoot especially since I don't build
with netcdf and error seems to be triggered by that.
Caused by: org.postgresql.util.PSQLException: ERROR: could not load
which is kinda bizzare because I wouldn't expect that to be loaded until
needed.
Anyrate the error suggests you are just out of memory. Is your JDBC
project running on same box as your PostgreSQL instance?
My guess would be that your JDBC Hibernate, is just hogging up resources
enough so PostGIS extension can't load. You don't see it in pgAdmin
perhaps because you are running pgAdmin from your desktop or it's not as
much of a resource hog.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3653#comment:1>
