[postgis-tickets] r15170 - Silence warning: ar: 'u' modifier ignored since 'D' is the default
Sandro Santilli strk at kbt.io
Thu Oct 6 03:43:42 PDT 2016
Author: strk
Date: 2016-10-06 03:43:42 -0700 (Thu, 06 Oct 2016)
New Revision: 15170
   trunk/configure.ac
See https://bugzilla.redhat.com/show_bug.cgi?id=1155273#c12
Modified: trunk/configure.ac
--- trunk/configure.ac	2016-10-03 20:22:15 UTC (rev 15169)
+++ trunk/configure.ac	2016-10-06 10:43:42 UTC (rev 15170)
@@ -46,6 +46,11 @@
 AC_SUBST([SQLPP])
 dnl
+dnl Silence warning: ar: 'u' modifier ignored since 'D' is the default
+dnl
+AC_SUBST(AR_FLAGS, [cr])
+dnl
 dnl Define PIC flags in PICFLAGS (note: this variable is set as part of libtool initialisation above)
 dnl
 PICFLAGS="$lt_prog_compiler_pic"
