[postgis-tickets] r15171 - In prep for 2.2.3 release
Regina Obe
lr at pcorp.us
Thu Oct 6 06:37:30 PDT 2016
Author: robe
Date: 2016-10-06 06:37:30 -0700 (Thu, 06 Oct 2016)
New Revision: 15171
branches/2.2/ChangeLog
branches/2.2/NEWS
branches/2.2/Version.config
branches/2.2/doc/release_notes.xml
branches/2.2/extensions/upgradeable_versions.mk
Modified: branches/2.2/ChangeLog
--- branches/2.2/ChangeLog 2016-10-06 10:43:42 UTC (rev 15170)
+++ branches/2.2/ChangeLog 2016-10-06 13:37:30 UTC (rev 15171)
@@ -1,3 +1,413 @@
+2016-10-03 20:20 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15167] NEWS, liblwgeom/lwstroke.c: #3652, crash on
+ collection(multicurve(curve))
+2016-09-27 08:22 Sandro Santilli <strk at keybit.net>
+ * [r15158] NEWS, postgis/postgis_module.c: Do not call printf from
+ interrupt handler, fixing deadlocks
+ Closes #3644 for 2.2 branch
+2016-09-25 11:41 Regina Obe <lr at pcorp.us>
+ * [r15142] NEWS,
+ extras/tiger_geocoder/geocode/interpolate_from_address.sql: fix
+ numeric in interpolate_from_address
+ Closes #3640 for PostGIS 2.2.3
+2016-09-25 11:36 Regina Obe <lr at pcorp.us>
+ * [r15141] regress/tickets.sql, regress/tickets_expected: Test to
+ trap FreeBSD crash on small tables.
+ References #2985 for PostGIS 2.2.3
+2016-09-25 03:54 Regina Obe <lr at pcorp.us>
+ * [r15137] NEWS,
+ extras/tiger_geocoder/normalize/normalize_address.sql,
+ extras/tiger_geocoder/pagc_normalize/pagc_normalize_address.sql:
+ tiger normalize, pagc_normalize integer out of range
+ closes #3641 for PostGIS 2.2.3
+2016-09-24 07:22 Regina Obe <lr at pcorp.us>
+ * [r15135] extensions/postgis/Makefile.in:
+ ../../utils/create_spatial_ref_sys_config_dump.pl: not found on
+ FreeBSD Add $PERL (my freebsd doesn't work without it)
+ Closes #3639 for PostGIS 2.2.3
+2016-09-23 06:39 Regina Obe <lr at pcorp.us>
+ * [r15130] NEWS, libpgcommon/Makefile.in, postgis/Makefile.in,
+ raster/rt_core/Makefile.in, raster/rt_pg/Makefile.in:
+ pgcommon/Makefile.in orders CFLAGS incorrectly leading to wrong
+ liblwgeom.h
+ (Fix to use source version instead of installed)
+ Patch from Greg Troxel
+ references #3604 for PostGIS 2.2.3
+2016-09-19 04:55 Regina Obe <lr at pcorp.us>
+ * [r15119] NEWS, doc/faq_raster.xml, doc/reference_constructor.xml,
+ doc/reference_raster.xml: doc corrections from ruvyn for PostGIS
+ 2.2.3
+ closes #3581
+ closes #3580
+ closes #3586
+ closes #3575
+2016-09-19 03:20 Regina Obe <lr at pcorp.us>
+ * [r15115] NEWS, raster/rt_pg/rtpostgis.sql.in: use ST_Union
+ instead of ST_Collect to compute raster max extent constraint
+ References #3501 for PostGIS 2.2.3
+2016-09-13 19:14 Daniel Baston <dbaston at gmail.com>
+ * [r15107] NEWS, liblwgeom/liblwgeom.h.in,
+ postgis/lwgeom_functions_basic.c, regress/tickets.sql,
+ regress/tickets_expected: #3569, Incorrect coordinates returned
+ by ST_CollectionHomogenize
+2016-09-13 19:09 Regina Obe <lr at pcorp.us>
+ * [r15106] regress/in_encodedpolyline.sql,
+ regress/in_encodedpolyline_expected: Add ST_SnapToGrid so 32-bit
+ and 64-bit answers agree
+ Closes #3629 for PostGIS 2.2
+2016-09-13 08:39 Sandro Santilli <strk at keybit.net>
+ * [r15103] topology/sql/populate.sql.in: Fix DEBUG build of
+ topology
+2016-09-09 14:28 Sandro Santilli <strk at keybit.net>
+ * [r15093] NEWS, raster/rt_pg/rtpostgis.sql.in,
+ raster/test/regress/rt_createoverview.sql,
+ raster/test/regress/rt_createoverview_expected: Fix schema
+ support in RT_CreateOveriew
+ Patch by hypostase
+ Closes #3615
+ Include tests
+2016-09-09 14:23 Sandro Santilli <strk at keybit.net>
+ * [r15091] NEWS: Note ST_SwapOrdinate capital-Y fix
+2016-09-09 14:22 Sandro Santilli <strk at keybit.net>
+ * [r15090] regress/swapordinates.sql,
+ regress/swapordinates_expected: Add test for ST_SwapOrdinate fix
+ (#3628)
+2016-09-09 14:02 Sandro Santilli <strk at keybit.net>
+ * [r15087] postgis/lwgeom_functions_basic.c: Fix lack of support
+ for capitalized-Y in SwapOrdinates
+ Closes #3628
+2016-09-08 16:06 Sandro Santilli <strk at keybit.net>
+ * [r15086] topology/postgis_topology.c: Really fix callback reading
+ Edge data in presence of unexpected NULLs
+2016-09-08 15:53 Sandro Santilli <strk at keybit.net>
+ * [r15084] topology/postgis_topology.c: Fix callback reading Edge
+ data in presence of unexpected NULLs
+2016-09-07 18:36 Sandro Santilli <strk at keybit.net>
+ * [r15082] regress/run_test.pl: Do not require expecting DISCARD
+ ALL
+ .. actually it may be a good idea to run it always after each
+ test ..
+2016-09-07 18:30 Sandro Santilli <strk at keybit.net>
+ * [r15081] regress/run_test.pl: Style only: remove trailing
+ blankspaces
+2016-09-06 22:59 Daniel Baston <dbaston at gmail.com>
+ * [r15076] NEWS: Add NEWS entry for #3627
+2016-09-06 22:57 Daniel Baston <dbaston at gmail.com>
+ * [r15075] postgis/lwgeom_export.c,
+ postgis/lwgeom_in_encoded_polyline.c,
+ regress/in_encodedpolyline.sql,
+ regress/in_encodedpolyline_expected,
+ regress/out_geometry_expected, regress/tickets.sql,
+ regress/tickets_expected: #3627, Encoded polyline functions
+ ignore precision parameter
+2016-09-06 15:37 Regina Obe <lr at pcorp.us>
+ * [r15073] NEWS, regress/run_test.pl: load_outdb related tests fix
+ for @INC change in perl
+ patch from Sebastiaan Couwenberg
+ closes #3624 for PostGIS 2.2
+2016-09-06 14:42 Regina Obe <lr at pcorp.us>
+ * [r15071] ci/winnie/package_postgis.sh: Fix svnurl export (no
+ longer trunk)
+2016-08-05 14:53 Sandro Santilli <strk at keybit.net>
+ * [r15039] NEWS, loader/shp2pgsql-cli.c: Allocate memory for
+ encoding argument, so it can be safely freed later.
+ Fixes #3608 for 2.2 branch
+ Patch by Matt Amos <zerebubuth at gmail.com>
+2016-08-05 14:11 Sandro Santilli <strk at keybit.net>
+ * [r15036] NEWS, liblwgeom/lwlinearreferencing.c,
+ regress/regress_lrs.sql, regress/regress_lrs_expected: Fix
+ inconsistency with multilinestring in
+ ST_LocateBetweenElevations()
+ Fixes #3607.
+ Includes testcase.
+ Patch by Artur Zakirov <a.zakirov at postgrespro.ru>
+2016-07-30 17:39 Regina Obe <lr at pcorp.us>
+ * [r15027] NEWS, extensions/address_standardizer/Makefile.in,
+ extensions/postgis_sfcgal/Makefile.in,
+ extensions/postgis_tiger_geocoder/Makefile.in: perl as found by
+ configure is not used in tiger, sfcgal, or address_standardizer
+ extensions
+ closes #3602 for PostGIS 2.2
+ tiger_data not being backed up and add upgrade test
+ closes #3515 for PostGIS 2.2
+2016-07-21 18:08 Sandro Santilli <strk at keybit.net>
+ * [r15020] .drone.yml: Update .drone.yml from trunk
+2016-07-21 17:42 Sandro Santilli <strk at keybit.net>
+ * [r15017] .drone.yml: Use -O0 for test builds, add reference to
+ postgis-docker
+ Removing the optimization flag reduces build time from ~40s to
+ ~30s
+2016-07-21 11:32 Sandro Santilli <strk at keybit.net>
+ * [r15009] .drone.yml, docker/build-test/Dockerfile.trisquel,
+ docker/build-test/Makefile: Remove docker config, update drone
+ Docker project moved to:
+ http://git.osgeo.org/gogs/postgis/postgis-docker
+2016-07-19 21:45 Sandro Santilli <strk at keybit.net>
+ * [r15001] README.md: Add Dronie badge
+ * [r15000] .drone.yml, docker, docker/build-test,
+ docker/build-test/Dockerfile.trisquel,
+ docker/build-test/Makefile: Add drone and docker config
+2016-07-05 10:51 Sandro Santilli <strk at keybit.net>
+ * [r14992] .gitlab-ci.yml: apt-get update && install on the same
+ line
+ This avoids attempts to install outdated packages due to cached
+ steps
+2016-07-02 16:33 Regina Obe <lr at pcorp.us>
+ * [r14982] doc/extras_tigergeocoder.xml: documentation corrections
+ from ruvyn for tiger geocoder
+ Closes #3593 for PostGIS 2.2
+2016-06-20 01:45 Regina Obe <lr at pcorp.us>
+ * [r14975] doc/reference_raster.xml: Doco fixes
+ closes #3584 for PostGIS 2.2
+ closes #3582 for PostGIS 2.2
+2016-06-20 01:31 Regina Obe <lr at pcorp.us>
+ * [r14973] doc/reference_raster.xml: typo geometries should be
+ rasters
+ closes #3585 for 2.2
+2016-06-15 20:37 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14956] NEWS, liblwgeom/lwgeom_geos.c, regress/tickets.sql,
+ regress/tickets_expected: #3579, crash in LWGEOM2GEOS
+2016-06-07 22:11 Daniel Baston <dbaston at gmail.com>
+ * [r14942] regress/knn_recheck.sql, regress/knn_recheck_expected,
+ regress/tickets.sql, regress/tickets_expected: Make test for
+ #3573 run only on PG 9.5+
+2016-06-07 13:49 Daniel Baston <dbaston at gmail.com>
+ * [r14940] NEWS, postgis/gserialized_gist_nd.c,
+ regress/tickets.sql, regress/tickets_expected: #3573, operator
+ <<->> incorrectly calculates m distance
+2016-06-04 18:18 Regina Obe <lr at pcorp.us>
+ * [r14933] NEWS, loader/Makefile.in, loader/icons,
+ loader/icons/hicolor, loader/icons/hicolor/16x16,
+ loader/icons/hicolor/16x16/apps,
+ loader/icons/hicolor/16x16/apps/shp2pgsql-gui.png,
+ loader/icons/hicolor/22x22, loader/icons/hicolor/22x22/apps,
+ loader/icons/hicolor/22x22/apps/shp2pgsql-gui.png,
+ loader/icons/hicolor/24x24, loader/icons/hicolor/24x24/apps,
+ loader/icons/hicolor/24x24/apps/shp2pgsql-gui.png,
+ loader/icons/hicolor/32x32, loader/icons/hicolor/32x32/apps,
+ loader/icons/hicolor/32x32/apps/shp2pgsql-gui.png,
+ loader/icons/hicolor/36x36, loader/icons/hicolor/36x36/apps,
+ loader/icons/hicolor/36x36/apps/shp2pgsql-gui.png,
+ loader/icons/hicolor/40x40, loader/icons/hicolor/40x40/apps,
+ loader/icons/hicolor/40x40/apps/shp2pgsql-gui.png,
+ loader/icons/hicolor/42x42, loader/icons/hicolor/42x42/apps,
+ loader/icons/hicolor/42x42/apps/shp2pgsql-gui.png,
+ loader/icons/hicolor/48x48, loader/icons/hicolor/48x48/apps,
+ loader/icons/hicolor/48x48/apps/shp2pgsql-gui.png,
+ loader/icons/hicolor/64x64, loader/icons/hicolor/64x64/apps,
+ loader/icons/hicolor/64x64/apps/shp2pgsql-gui.png,
+ loader/icons/hicolor/8x8, loader/icons/hicolor/8x8/apps,
+ loader/icons/hicolor/8x8/apps/shp2pgsql-gui.png,
+ loader/shp2pgsql-gui.desktop: Install desktop file and
+ application icons for shp2pgsql-gui (Sebastiaan Couwenberg)
+ Closes #3571 for PostGIS 2.2
+2016-05-25 17:28 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14920] NEWS, postgis/lwgeom_functions_basic.c,
+ regress/tickets.sql, regress/tickets_expected: #3565, st_setpoint
+ crashes database
+2016-05-12 19:11 Regina Obe <lr at pcorp.us>
+ * [r14900] extras/tiger_geocoder/geocode/reverse_geocode.sql:
+ Closes #3552 for PostGIS 2.2.3
+2016-05-12 18:58 Regina Obe <lr at pcorp.us>
+ * [r14898] extras/tiger_geocoder/geocode/geocode_address.sql: fix
+ regexp mistake need to cast to text.
+2016-05-12 09:44 Sandro Santilli <strk at keybit.net>
+ * [r14896] README.md: Fix winnie image link
+2016-05-12 09:19 Sandro Santilli <strk at keybit.net>
+ * [r14895] README.md: Update debbie and winnie links to use https
+2016-05-04 22:02 Daniel Baston <dbaston at gmail.com>
+ * [r14884] postgis/lwgeom_accum.c, postgis/lwgeom_geos.c,
+ regress/tickets.sql, regress/tickets_expected: #3470,
+ ST_Polygonize doesn't accept NULL geometries
+2016-05-01 16:23 Daniel Baston <dbaston at gmail.com>
+ * [r14874] doc/reference_measure.xml, regress/tickets.sql,
+ regress/tickets_expected: #3119, Wrong documented behavior for
+ ST_LengthSpheroid
+2016-04-27 12:12 Daniel Baston <dbaston at gmail.com>
+ * [r14865] doc/reference_raster.xml: #3218, ST_PixelAsCentroid
+ documentation has incorrect names
+2016-04-27 12:06 Daniel Baston <dbaston at gmail.com>
+ * [r14862] doc/reference_raster.xml: #3217, ST_Value documentation
+ has incorrect parameter names
+2016-04-18 08:42 Sandro Santilli <strk at keybit.net>
+ * [r14852] README.md: Fix gilab-ci badge
+2016-04-17 21:45 Regina Obe <lr at pcorp.us>
+ * [r14849] extras/tiger_geocoder/geocode/geocode.sql,
+ extras/tiger_geocoder/geocode/geocode_address.sql,
+ extras/tiger_geocoder/geocode/geocode_intersection.sql: Schema
+ qualify calls and prevent error when tiger street number is not a
+ number (just return first number part)
+ References #3531 #3451 for PostGIS 2.2.3
+2016-04-17 20:38 Regina Obe <lr at pcorp.us>
+ * [r14848] extras/tiger_geocoder/geocode/geocode_intersection.sql:
+ Minor cleanup, change to schema qualify tables,
+ change to use tiger node ids overlap instead of intersects for
+ determining intersections
+ Closes #3530 for PostGIS 2.2.3
+ References #3451
+2016-04-13 16:53 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14840] regress/subdivide.sql, regress/subdivide_expected,
+ regress/tickets.sql: #3529, move test to subdivide.sql
+2016-04-13 15:57 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14837] regress/tickets.sql, regress/tickets_expected: Don't run
+ online test for GEOS 3.5 feature
+2016-04-12 21:39 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14834] NEWS, liblwgeom/cunit/cu_clip_by_rect.c,
+ liblwgeom/lwgeom.c, regress/tickets.sql,
+ regress/tickets_expected: #3522, handle POINT and MULTIPOINT
+ correctly in ST_Subdivide
+2016-04-12 19:19 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14831] NEWS, liblwgeom/lwgeodetic.c: #3524, add
+ interruptibility to geography brute force distance calculation
+2016-04-11 18:40 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14829] spatial_ref_sys.sql: #1851, spatial_ref_sys entries for
+ Pulkovo_1942_58, to_wgs84
+2016-03-22 19:57 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14801] NEWS, doc/release_notes.xml: Fix rel notes on
+ ST_Intersects
+2016-03-22 18:23 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14798] NEWS, README.postgis, Version.config: Bump working
+ versions to 2.2.3dev
+2016-03-22 17:51 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14796] ChangeLog, NEWS, README.postgis, Version.config,
+ doc/release_notes.xml, extensions/upgradeable_versions.mk:
+ Version bumps, release notes for 2.2.2
+2016-03-22 16:43 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14795] postgis, raster/rt_pg: Ignore built artifacts
2016-03-20 05:07 Regina Obe <lr at pcorp.us>
* [r14791] doc/reference_output.xml: fix typo in last commit
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS 2016-10-06 10:43:42 UTC (rev 15170)
+++ branches/2.2/NEWS 2016-10-06 13:37:30 UTC (rev 15171)
@@ -1,5 +1,5 @@
PostGIS 2.2.3
-2016/09/XX
+2016/10/06
* Bug Fixes *
Modified: branches/2.2/Version.config
--- branches/2.2/Version.config 2016-10-06 10:43:42 UTC (rev 15170)
+++ branches/2.2/Version.config 2016-10-06 13:37:30 UTC (rev 15171)
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=2
POSTGIS_MINOR_VERSION=2
-POSTGIS_MICRO_VERSION=3dev
+POSTGIS_MICRO_VERSION=3
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
Modified: branches/2.2/doc/release_notes.xml
--- branches/2.2/doc/release_notes.xml 2016-10-06 10:43:42 UTC (rev 15170)
+++ branches/2.2/doc/release_notes.xml 2016-10-06 13:37:30 UTC (rev 15171)
@@ -2,13 +2,53 @@
<appendix id="release_notes">
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
+ <sect1>
+ <title>Release 2.2.3</title>
+ <para>Release date: 2016/10/06</para>
+ <para>This is a bug fix and performance improvement release.</para>
+ <simplesect>
+ <title>Bug Fixes and Enhancements</title>
+ <para>3615, Fix schema support in RT_CreateOveriew (Cait Smith)</para>
+ <para>3628, Fix lack of support for capitalized-Y in SwapOrdinates</para>
+ <para>3524, Add interruptibility to geography brute-force distance
+ calculation</para>
+ <para>3522, Handle POINT and MULTIPOINT correctly in ST_Subdivide</para>
+ <para>3565, ST_SetPoint can crash backend</para>
+ <para>3571, Install desktop file and application icons
+ for shp2pgsql-gui (Sebastiaan Couwenberg)</para>
+ <para>3573, Operator <<->> incorrectly calculates m distance</para>
+ <para>3579, Crash in LWGEOM2GEOS</para>
+ <para>3515, tiger_data not being backed up</para>
+ <para>3569, Incorrect coordinates returned by ST_CollectionHomogenize
+ (Dan Baston)</para>
+ <para>3602, perl as found by configure is not used
+ in tiger extension, postgis_sfcgal, address_standardizer</para>
+ <para>3604, pgcommon/Makefile.in orders CFLAGS leads to installed liblwgeom.h
+ (Greg Troxel)</para>
+ <para>3607, Fix inconsistency with multilinestring in
+ ST_LocateBetweenElevations (Artur Zakirov)</para>
+ <para>3608, Fix crash passing -W UTF-8 to shp2pgsql (Matt Amos)</para>
+ <para>3624, [raster] load_outdb related tests fail
+ for 2.2.2 & 2.3.0-beta1 on Debian unstable
+ perl @INC fix (Sebastiaan Couwenberg)</para>
+ <para>3627, Encoded polyline functions ignore precision parameter
+ (Christian Quest / Dan Baston)</para>
+ <para>3501, use ST_Union instead of ST_Collect to compute
+ raster max extent constraint</para>
+ <para>3640, Interpolate_from_address sometimes results in "" invalid for numeric</para>
+ <para>3641, Tiger normalize, pagc_normalize integer out of range</para>
+ <para>3644, Deadlock on interrupt</para>
+ <para>3542, Crash on Geometry(MultiCurve())</para>
+ <para>Numerous documentation corrections from ruvyn</para>
+ </simplesect>
+ </sect1>
<sect1>
<title>Release 2.2.2</title>
<para>Release date: 2016/03/22</para>
<simplesect>
- <title>New Features</title>
+ <title>Bug Fixes and Enhancments</title>
<para>#3463, Fix crash on face-collapsing edge change</para>
<para>#3422, Improve ST_Split robustness on standard precision double systems (arm64, ppc64el, s390c, powerpc, ...)</para>
<para>#3427, Update spatial_ref_sys to EPSG version 8.8</para>
Modified: branches/2.2/extensions/upgradeable_versions.mk
--- branches/2.2/extensions/upgradeable_versions.mk 2016-10-06 10:43:42 UTC (rev 15170)
+++ branches/2.2/extensions/upgradeable_versions.mk 2016-10-06 13:37:30 UTC (rev 15171)
@@ -19,4 +19,5 @@
2.1.9 \
2.2.0 \
2.2.1 \
- 2.2.2
+ 2.2.2 \
+ 2.2.3dev
