[postgis-tickets] [PostGIS] #2841: ST_MinimumBoundingCircle and ST_ConcaveHull not covering original
PostGIS trac at osgeo.org
Wed Sep 7 10:52:02 PDT 2016
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  reopened
  Priority:  medium   |  Milestone:  PostGIS 2.2.3
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Changes (by dbaston):
 * cc: mtoews (added)
Comment:
 Replying to [comment:11 komzpa]:
 > I'd say that I prefer Polygon as bounding circle.
 > Does it make the case in the ticket pass?
 My bad, I changed the function to produce a polygon.  Yes, it makes the
 case in the ticket pass.  With this function, as the number of segments
 increases, the polygon shrinks towards a true circle, rather than
 expanding towards a true circle (as with ST_Buffer).
 Wrapping this up into a single function:
 CREATE OR REPLACE FUNCTION mbc_test (geom geometry, segments_per_quad int)
 RETURNS geometry AS $$
 DECLARE
 center geometry;
 radius float;
 points geometry[];
 theta float;
 segments int;
 r float;
 i int;
 BEGIN
     segments := segments_per_quad * 4;
     SELECT (c).center, (c).radius FROM (SELECT
 ST_MinimumBoundingRadius(geom) c) sq INTO center, radius;
     theta := 2 * pi() / segments;
     r := radius * sqrt(1 + tan(theta/2)^2); -- use excircle instead of
 incircle
     FOR i IN SELECT generate_series(0, segments) LOOP
         points[i] := ST_Translate(center, r*sin(i*theta), r*cos(i*theta));
     END LOOP;
     RETURN ST_MakePolygon(ST_MakeLine(points));
 END;
 $$ LANGUAGE PLPGSQL;
 Any reasons not to use this logic instead of the current ST_Buffer on the
 center point?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2841#comment:12>
