[postgis-tickets] [PostGIS] #3615: ST_CreateOverview conflict on cast to regclass for duplicate table name
PostGIS trac at osgeo.org
Thu Sep 8 06:07:10 PDT 2016
  Reporter:  hypostase  |      Owner:  pramsey
      Type:  defect     |     Status:  reopened
  Priority:  medium     |  Milestone:  PostGIS 2.3.0
 Component:  postgis    |    Version:  2.2.x
Resolution:             |   Keywords:
Comment (by hypostase):
 I've added the tests all to the rt_createoverview file.
 It checks with path set via search_path, and with schema explicitly named.
 It uses a larger raster for the schema table to ensure the values are
 different between the original and schema rasters.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3615#comment:10>
