[postgis-tickets] r15519 - missed file commit for ST_Centroid Geography support
Regina Obe lr at pcorp.us
Fri Aug 4 09:23:31 PDT 2017
Author: robe
Date: 2017-08-04 09:23:31 -0700 (Fri, 04 Aug 2017)
New Revision: 15519
Added:
   trunk/postgis/geography_centroid.c
references #2951
Added: trunk/postgis/geography_centroid.c
--- trunk/postgis/geography_centroid.c	                        (rev 0)
+++ trunk/postgis/geography_centroid.c	2017-08-04 16:23:31 UTC (rev 15519)
@@ -0,0 +1,386 @@
+ * PostGIS - Spatial Types for PostgreSQL
+ * http://postgis.net
+ * PostGIS is free software: you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation, either version 2 of the License, or
+ * (at your option) any later version.
+ * PostGIS is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with PostGIS.  If not, see <http://www.gnu.org/licenses/>.
+ * Copyright (C) 2017 Danny Götte <danny.goette at fem.tu-ilmenau.de>
+#include "postgres.h"
+#include "../postgis_config.h"
+#include <math.h>
+#include "liblwgeom.h"         /* For standard geometry types. */
+#include "lwgeom_pg.h"       /* For pg macros. */
+#include "lwgeom_transform.h" /* For SRID functions */
+Datum geography_centroid(PG_FUNCTION_ARGS);
+/* internal functions */
+LWPOINT* geography_centroid_from_wpoints(const uint32_t srid, const POINT3DM* points, const uint32_t size);
+LWPOINT* geography_centroid_from_mline(const LWMLINE* mline, SPHEROID* s);
+LWPOINT* geography_centroid_from_mpoly(const LWMPOLY* mpoly, bool use_spheroid, SPHEROID* s);
+LWPOINT* cart_to_lwpoint(const double_t x_sum, const double_t y_sum, const double_t z_sum, const double_t weight_sum, const uint32_t srid);
+POINT3D* lonlat_to_cart(const double_t raw_lon, const double_t raw_lat);
+ * geography_centroid(GSERIALIZED *g)
+ * returns centroid as point
+PG_FUNCTION_INFO_V1(geography_centroid);
+	LWGEOM *lwgeom = NULL;
+	LWGEOM *lwgeom_out = NULL;
+    LWPOINT *lwpoint_out = NULL;
+	GSERIALIZED *g = NULL;
+	GSERIALIZED *g_out = NULL;
+    uint32_t srid;
+    bool use_spheroid = true;
+    SPHEROID s;
+	uint32_t type;
+	/* Get our geometry object loaded into memory. */
+	g = PG_GETARG_GSERIALIZED_P(0);
+	lwgeom = lwgeom_from_gserialized(g);
+	if (g == NULL)
+		PG_RETURN_NULL();
+	srid = lwgeom_get_srid(lwgeom);
+	/* on empty input, return empty output */
+	if (gserialized_is_empty(g))
+		LWCOLLECTION* empty = lwcollection_construct_empty(COLLECTIONTYPE, srid, 0, 0);
+	 	lwgeom_out = lwcollection_as_lwgeom(empty);
+		lwgeom_set_geodetic(lwgeom_out, true);
+		g_out = gserialized_from_lwgeom(lwgeom_out, 0);
+		PG_RETURN_POINTER(g_out);
+    /* Initialize spheroid */
+    spheroid_init_from_srid(fcinfo, srid, &s);
+    /* Set to sphere if requested */
+    use_spheroid = PG_GETARG_BOOL(1);
+	if ( ! use_spheroid )
+		s.a = s.b = s.radius;
+	type = gserialized_get_type(g);
+	switch (type)
+	case POINTTYPE:
+        /* centroid of a point is itself */
+        PG_RETURN_POINTER(g);
+        break;
+	case MULTIPOINTTYPE:
+        LWMPOINT* mpoints = lwgeom_as_lwmpoint(lwgeom);
+        /* average between all points */
+        uint32_t size = mpoints->ngeoms;
+        POINT3DM points[size];
+		uint32_t i;
+		for (i = 0; i < size; i++) {
+            points[i].x = lwpoint_get_x(mpoints->geoms[i]);
+            points[i].y = lwpoint_get_y(mpoints->geoms[i]);
+            points[i].m = 1;
+		lwpoint_out = geography_centroid_from_wpoints(srid, points, size);
+        break;
+	case LINETYPE:
+        LWLINE* line = lwgeom_as_lwline(lwgeom);
+        /* reuse mline function */
+        LWMLINE* mline = lwmline_construct_empty(srid, 0, 0);
+        lwmline_add_lwline(mline, line);
+        lwpoint_out = geography_centroid_from_mline(mline, &s);
+        lwmline_free(mline);
+		break;
+	case MULTILINETYPE:
+        LWMLINE* mline = lwgeom_as_lwmline(lwgeom);
+		break;
+	case POLYGONTYPE:
+        LWPOLY* poly = lwgeom_as_lwpoly(lwgeom);
+        /* reuse mpoly function */
+        LWMPOLY* mpoly = lwmpoly_construct_empty(srid, 0, 0);
+        lwmpoly_add_lwpoly(mpoly, poly);
+        lwpoint_out = geography_centroid_from_mpoly(mpoly, use_spheroid, &s);
+        lwmpoly_free(mpoly);
+        break;
+	case MULTIPOLYGONTYPE:
+        LWMPOLY* mpoly = lwgeom_as_lwmpoly(lwgeom);
+        break;
+	default:
+		elog(ERROR, "ST_Centroid(geography) unhandled geography type");
+		PG_RETURN_NULL();
+	PG_FREE_IF_COPY(g, 0);
+    lwgeom_out = lwpoint_as_lwgeom(lwpoint_out);
+ * Convert lat-lon-points to x-y-z-coordinates, calculate a weighted average
+ * point and return lat-lon-coordinated
+    double_t x_sum = 0;
+    double_t y_sum = 0;
+    double_t z_sum = 0;
+    double_t weight_sum = 0;
+    double_t weight = 1;
+    POINT3D* point;
+	uint32_t i;
+	for (i = 0; i < size; i++ )
+		point = lonlat_to_cart(points[i].x, points[i].y);
+        weight = points[i].m;
+        x_sum += point->x * weight;
+        y_sum += point->y * weight;
+        z_sum += point->z * weight;
+        weight_sum += weight;
+		lwfree(point);
+    return cart_to_lwpoint(x_sum, y_sum, z_sum, weight_sum, srid);
+    double_t lat, lon;
+    double_t sin_lat;
+    POINT3D* point = lwalloc(sizeof(POINT3D));;
+    // prepare coordinate for trigonometric functions from [-90, 90] -> [0, pi]
+    lat = (raw_lat + 90) / 180 * M_PI;
+    // prepare coordinate for trigonometric functions from [-180, 180] -> [-pi, pi]
+    lon = raw_lon / 180 * M_PI;
+    /* calculate value only once */
+    sin_lat = sinl(lat);
+    /* convert to 3D cartesian coordinates */
+    point->x = sin_lat * cosl(lon);
+    point->y = sin_lat * sinl(lon);
+    point->z = cosl(lat);
+    return point;
+    double_t x = x_sum / weight_sum;
+    double_t y = y_sum / weight_sum;
+    double_t z = z_sum / weight_sum;
+    /* x-y-z vector length */
+    double_t r = sqrtl(powl(x, 2) + powl(y, 2) + powl(z, 2));
+    double_t lon = atan2l(y, x) * 180 / M_PI;
+    double_t lat = acosl(z / r) * 180 / M_PI - 90;
+	return lwpoint_make2d(srid, lon, lat);
+ * Split lines into segments and calculate with middle of segment as weighted
+ * point.
+    double_t tolerance = 0.0;
+    uint32_t size = 0;
+	uint32_t i, k;
+    /* get total number of points */
+    for (i = 0; i < mline->ngeoms; i++) {
+        size += (mline->geoms[i]->points->npoints - 1) * 2;
+    uint32_t j = 0;
+        LWLINE* line = mline->geoms[i];
+        /* add both points of line segment as weighted point */
+        for (k = 0; k < line->points->npoints - 1; k++) {
+            const POINT2D* p1 = getPoint2d_cp(line->points, k);
+            const POINT2D* p2 = getPoint2d_cp(line->points, k+1);
+            /* use line-segment length as weight */
+            LWPOINT* lwp1 = lwpoint_make2d(mline->srid, p1->x, p1->y);
+            LWPOINT* lwp2 = lwpoint_make2d(mline->srid, p2->x, p2->y);
+            LWGEOM* lwgeom1 = lwpoint_as_lwgeom(lwp1);
+            LWGEOM* lwgeom2 = lwpoint_as_lwgeom(lwp2);
+            lwgeom_set_geodetic(lwgeom1, LW_TRUE);
+            lwgeom_set_geodetic(lwgeom2, LW_TRUE);
+            /* use point distance as weight */
+            double_t weight = lwgeom_distance_spheroid(lwgeom1, lwgeom2, s, tolerance);
+            points[j].x = p1->x;
+            points[j].y = p1->y;
+            points[j].m = weight;
+            j++;
+            points[j].x = p2->x;
+            points[j].y = p2->y;
+            j++;
+            lwgeom_free(lwgeom1);
+            lwgeom_free(lwgeom2);
+    return geography_centroid_from_wpoints(mline->srid, points, size);
+ * Split polygons into triangles and use centroid of the triangle with the
+ * triangle area as weight to calculate the centroid of a (multi)polygon.
+	uint32_t i, ir, ip;
+    for (ip = 0; ip < mpoly->ngeoms; ip++) {
+		for (ir = 0; ir < mpoly->geoms[ip]->nrings; ir++) {
+        	size += mpoly->geoms[ip]->rings[ir]->npoints;
+    uint32_t j = 0;
+    GBOX gbox;
+    /* use first point as reference to create triangles */
+    const POINT4D* reference_point = (const POINT4D*) getPoint2d_cp(mpoly->geoms[0]->rings[0], 0);
+        LWPOLY* poly = mpoly->geoms[ip];
+        for (ir = 0; ir < poly->nrings; ir++) {
+            POINTARRAY* ring = poly->rings[ir];
+            /* split into triangles (two points + reference point) */
+            for (i = 0; i < ring->npoints - 1; i++) {
+                const POINT4D* p1 = (const POINT4D*) getPoint2d_cp(ring, i);
+                const POINT4D* p2 = (const POINT4D*) getPoint2d_cp(ring, i+1);
+                POINTARRAY* pa = ptarray_construct_empty(0, 0, 4);
+                ptarray_insert_point(pa, p1, 0);
+                ptarray_insert_point(pa, p2, 1);
+                ptarray_insert_point(pa, reference_point, 2);
+                ptarray_insert_point(pa, p1, 3);
+                LWPOLY* poly_tri = lwpoly_construct_empty(mpoly->srid, 0, 0);
+                lwpoly_add_ring(poly_tri, pa);
+                LWGEOM* geom_tri = lwpoly_as_lwgeom(poly_tri);
+                lwgeom_set_geodetic(geom_tri, LW_TRUE);
+            	/* Calculate the weight of the triangle. If counter clockwise,
+                 * the weight is negative (e.g. for holes in polygons)
+                double_t weight;
+            	if ( use_spheroid )
+            		weight = lwgeom_area_spheroid(geom_tri, s);
+            	else
+            		weight = lwgeom_area_sphere(geom_tri, s);
+                POINT3DM triangle[3];
+                triangle[0].x = p1->x;
+                triangle[0].y = p1->y;
+                triangle[0].m = 1;
+                triangle[1].x = p2->x;
+                triangle[1].y = p2->y;
+                triangle[1].m = 1;
+                triangle[2].x = reference_point->x;
+                triangle[2].y = reference_point->y;
+                triangle[2].m = 1;
+                /* get center of triangle */
+                LWPOINT* tri_centroid = geography_centroid_from_wpoints(mpoly->srid, triangle, 3);
+                points[j].x = lwpoint_get_x(tri_centroid);
+                points[j].y = lwpoint_get_y(tri_centroid);
+                j++;
+				lwpoint_free(tri_centroid);
+                lwgeom_free(geom_tri);
+    return geography_centroid_from_wpoints(mpoly->srid, points, size);
