[postgis-tickets] [PostGIS] #2951: ST_Centroid for geography
trac at osgeo.org
Fri Aug 4 12:59:01 PDT 2017
Reporter: Mike Toews | Owner: robe
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.4.0
Component: liblwgeom | Version:
Resolution: | Keywords:
Comment (by robe):
I think there is some memory pollution issue left at least with the
multipolygon centroid checks. I also think the calc for multipolygon may
be a little off, but I'd have to do further spot checks to be sure.
Attached is a table dump of geometries that centroid seems enough from
what I would expect.
I'm testing this on PostgreSQL 10beta2 and haven't ruled out it's not a 10
specific bug.
The thing that most troubles me is the memory pollution.
SELECT id, ST_AsText(ST_Centroid(geog)) AS geog_cent,
ST_AsText(ST_Transform(ST_Centroid(ST_Transform(geog::geometry,26986)),4326))
AS sm_cent,
ST_Distance(ST_Transform(ST_Centroid(ST_Transform(geog::geometry,26986)),4326)::geography,
ST_Centroid(geog)) As dist_disp
FROM geog_cent_poly_prob
WHERE id IN( 49);
yields this:
id | geog_cent | sm_cent
| dist_disp
49 | POINT(-71.0758016600248 42.4106304684328) | POINT(-71.0757460620397
42.4107333642771) | 8466479.12566751
(1 row)
I'm guessing the first call to ST_Centroid yields the right answer (those
the as text looks okay), but the second call where I stuff it in a
distance check gives some huge number presumably because it computed
something crazy for the centroid.
Now something different happens if I run my test with more than one
record:
AS sm_cent,
FROM geog_cent_poly_prob;
| dist_disp
1 | POINT(-71.0703129986404 42.3452999176663) | POINT(-71.0703048387431
42.3453017868431) | 0.7037137
5 | POINT(-71.037584398837 42.336384333772) | POINT(-71.0428341568715
42.3388586422701) | 512.55960119
49 | POINT(-71.0758046647449 42.4106309813902) | POINT(-71.0757460620397
42.4107333642771) | NaN
(3 rows)
I get NaN. If I run in pgAdmin instead of PSSQL, I've seen geog_cent
return a POINT(0...).
To prove it's the ST_Centroid,
ST_AsText(ST_Centroid(geog)) As geog_cent2
id | geog_cent |
geog_cent2
1 | POINT(-71.0703129986404 42.3452999176663) | POINT(-71.0703129986404
42.3452999176663)
5 | POINT(-71.037584398837 42.336384333772) | POINT(-71.037584398837
42.336384333772)
49 | POINT(-71.1593947384227 42.3629042590461) | POINT(-71.0945591847874
42.3518693374157)
(3 rows)
Note how the same exact query ST_AsText(ST_Centroid(...)) gives two
different answers for the id=49 case.
I've attached the sample table.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2951#comment:18>
