[postgis-tickets] r15524 - Clarify description of ST_Snap that it is the newly snapped input geometry and will return input geometry unchanged if no snapping.
Regina Obe
lr at pcorp.us
Sat Aug 5 04:16:49 PDT 2017
Author: robe
Date: 2017-08-05 04:16:49 -0700 (Sat, 05 Aug 2017)
New Revision: 15524
branches/2.3/doc/reference_editor.xml
Modified: branches/2.3/doc/reference_editor.xml
--- branches/2.3/doc/reference_editor.xml 2017-08-04 23:02:43 UTC (rev 15523)
+++ branches/2.3/doc/reference_editor.xml 2017-08-05 11:16:49 UTC (rev 15524)
@@ -1732,6 +1732,8 @@
Snaps the vertices and segments of a geometry
another Geometry's vertices.
A snap distance tolerance is used to control where snapping is performed.
+ The result geometry is the input geometry with the vertices snapped.
+ If no snapping occurs then the input geometry is returned unchanged.
</para>
<para>
Snapping one geometry to another can improve
