[postgis-tickets] r15523 - revert last change seems other things I borught over from 2.4 where are unrelated to #3800
Regina Obe
lr at pcorp.us
Fri Aug 4 16:02:43 PDT 2017
Author: robe
Date: 2017-08-04 16:02:43 -0700 (Fri, 04 Aug 2017)
New Revision: 15523
branches/2.3/loader/shp2pgsql-core.c
Modified: branches/2.3/loader/shp2pgsql-core.c
--- branches/2.3/loader/shp2pgsql-core.c 2017-08-04 22:49:07 UTC (rev 15522)
+++ branches/2.3/loader/shp2pgsql-core.c 2017-08-04 23:02:43 UTC (rev 15523)
@@ -9,7 +9,7 @@
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU General Public Licence. See the COPYING file.
- * Maintainer: Paul Ramsey <pramsey at cleverelephant.ca>
+ * Maintainer: Paul Ramsey <pramsey at opengeo.org>
@@ -248,7 +248,7 @@
/* Create a ptarray containing a single point */
POINTARRAY *pa = ptarray_construct_empty(state->has_z, state->has_m, 1);
/* Generate the point */
point4d.x = obj->padfX[u];
point4d.y = obj->padfY[u];
@@ -294,7 +294,7 @@
/* Free all of the allocated items */
lwgeom_free(lwgeom);
/* Return the string - everything ok */
*geometry = mem;
@@ -639,7 +639,7 @@
for (pi = 0; pi < polygon_total; pi++)
LWPOLY *lwpoly = lwpoly_construct_empty(state->from_srid, state->has_z, state->has_m);
Ring *polyring;
int ring_index = 0;
@@ -856,8 +856,8 @@
return SHPLOADERERR;
/* Open the column map if one was specified */
if (state->config->column_map_filename)
@@ -865,7 +865,7 @@
&state->column_map, state->message, SHPLOADERMSGLEN);
if (!ret) return SHPLOADERERR;
/* User hasn't altered the default encoding preference... */
if ( strcmp(state->config->encoding, ENCODING_DEFAULT) == 0 )
@@ -1023,7 +1023,7 @@
break;
/* Force Z/M-handling if configured to do so */
switch(state->config->force_output)
@@ -1096,7 +1096,6 @@
state->types[j] = type;
state->widths[j] = field_width;
state->precisions[j] = field_precision;
-/* fprintf(stderr, "XXX %s width:%d prec:%d\n", name, field_width, field_precision); */
if (state->config->encoding)
@@ -1122,7 +1121,7 @@
strncpy(name, utf8str, MAXFIELDNAMELEN);
free(utf8str);
/* If a column map file has been passed in, use this to create the postgresql field name from
the dbf column name */
@@ -1193,7 +1192,7 @@
if (state->config->forceint4 || (state->widths[j] >=5 && state->widths[j] < 10))
state->pgfieldtypes[j] = malloc(strlen("int4") + 1);
- strcpy(state->pgfieldtypes[j], "int4");
+ strcpy(state->pgfieldtypes[j], "int4");
else if (state->widths[j] < 5)
@@ -1209,8 +1208,6 @@
case FTDouble:
/* Determine exact type based upon field width */
- fprintf(stderr, "Field %s is an FTDouble with width %d and precision %d\n",
- state->field_names[j], state->widths[j], state->precisions[j]);
if (state->widths[j] > 18)
state->pgfieldtypes[j] = malloc(strlen("numeric") + 1);
@@ -1232,7 +1229,7 @@
snprintf(state->message, SHPLOADERMSGLEN, _("Invalid type %x in DBF file"), state->types[j]);
strcat(state->col_names, "\"");
strcat(state->col_names, name);
@@ -1270,13 +1267,13 @@
for handling string resizing during append */
sb = stringbuffer_create();
stringbuffer_clear(sb);
/* Set the client encoding if required */
stringbuffer_aprintf(sb, "SET CLIENT_ENCODING TO UTF8;\n");
/* Use SQL-standard string escaping rather than PostgreSQL standard */
stringbuffer_aprintf(sb, "SET STANDARD_CONFORMING_STRINGS TO ON;\n");
@@ -1347,7 +1344,7 @@
/* First output the raw field type string */
stringbuffer_aprintf(sb, "%s", state->pgfieldtypes[j]);
/* Some types do have typmods though... */
if (!strcmp("varchar", state->pgfieldtypes[j]))
stringbuffer_aprintf(sb, "(%d)", state->widths[j]);
@@ -1521,8 +1518,8 @@
- /* Skip deleted records */
- if (state->hDBFHandle && DBFIsRecordDeleted(state->hDBFHandle, item))
+ /* If we are reading the DBF only and the record has been marked deleted, return deleted record status */
+ if (state->config->readshape == 0 && DBFIsRecordDeleted(state->hDBFHandle, item))
*strrecord = NULL;
return SHPLOADERRECDELETED;
@@ -1682,7 +1679,7 @@
/* Force the locale to C */
char *oldlocale = setlocale(LC_NUMERIC, "C");
/* Handle the case of a NULL shape */
if (obj->nVertices == 0)
@@ -1775,7 +1772,7 @@
/* Tidy up everything */
SHPDestroyObject(obj);
setlocale(LC_NUMERIC, oldlocale);
@@ -1869,7 +1866,7 @@
/* Destroy a state object created with ShpLoaderOpenShape */
int i;
if (state != NULL)
if (state->hSHPHandle)
@@ -1887,7 +1884,7 @@
for (i = 0; i < state->num_fields; i++)
free(state->pgfieldtypes[i]);
free(state->pgfieldtypes);
if (state->types)
@@ -1901,7 +1898,7 @@
/* Free any column map fieldnames if specified */
colmap_clean(&state->column_map);
/* Free the state itself */
free(state);
