[postgis-tickets] [PostGIS] #3801: postgis dump restore test is broken
trac at osgeo.org
Sat Aug 5 09:22:12 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.4.0
Component: build/upgrade/install | Version: 2.3.x
Resolution: fixed | Keywords:
Changes (by robe):
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"15528" 15528]:
#!CommitTicketReference repository="" revision="15528"
Fix dump/restore test (arguments out of order)
Closes #3801 for PostGIS 2.4.0
Turn off interrupt tests on dronie, too many false failures
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3801#comment:3>
