[postgis-tickets] [PostGIS] #3801: postgis dump restore test is broken
trac at osgeo.org
Sat Aug 5 09:48:17 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.4.0
Component: build/upgrade/install | Version: 2.3.x
Resolution: | Keywords:
Comment (by robe):
okay travis's problems seem to be permission related. On closer
inspection.
psql:/home/travis/build/postgis/postgis/regress/00-regress-
install/share/contrib/postgis/postgis.sql:97: ERROR: could not access
file "/home/travis/build/postgis/postgis/regress/00-regress-
install/lib/postgis-2.4": Permission denied
make[1]: *** [check] Error 1
make[1]: Leaving directory `/home/travis/build/postgis/postgis/regress'
make: *** [check] Error 1
I'm not sure why this changed. Before it started failing last commit was
just a change to NEWS file. So must be a change in travis itself with
permissions.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3801#comment:6>
