[postgis-tickets] [PostGIS] #3801: postgis dump restore test is broken
PostGIS trac at osgeo.org
Sat Aug 5 09:49:33 PDT 2017
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  reopened
  Priority:  medium                 |  Milestone:  PostGIS 2.4.0
 Component:  build/upgrade/install  |    Version:  2.3.x
Resolution:                         |   Keywords:
Comment (by robe):
 In [changeset:"15530" 15530]:
 #!CommitTicketReference repository="" revision="15530"
 try to fix travis check failures by sudoing more stuff.
 References #3801 for PostGIS 2.4.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3801#comment:7>
