[postgis-tickets] r15531 - switch travis back not using sudo (root doesn't exist).
Regina Obe
lr at pcorp.us
Sat Aug 5 09:58:26 PDT 2017
Author: robe
Date: 2017-08-05 09:58:26 -0700 (Sat, 05 Aug 2017)
New Revision: 15531
trunk/.travis.yml
Try forcing precise (July 18 default of travis switched to trusty which is around when we started having problems).
Modified: trunk/.travis.yml
--- trunk/.travis.yml 2017-08-05 16:49:32 UTC (rev 15530)
+++ trunk/.travis.yml 2017-08-05 16:58:26 UTC (rev 15531)
@@ -16,17 +16,18 @@
- ./autogen.sh
language: c
+dist: precise
compiler: gcc
script:
- ./configure
- make
- - sudo make check
- - sudo make check RUNTESTFLAGS='--dumprestore'
+ - make check
+ - make check RUNTESTFLAGS='--dumprestore'
- sudo make install
- - sudo make installcheck
- - sudo make installcheck RUNTESTFLAGS='--dumprestore'
+ - make installcheck
+ - make installcheck RUNTESTFLAGS='--dumprestore'
notifications:
email: false
