[postgis-tickets] [PostGIS] #3803: travis needs to have script revised to work with trusty
trac at osgeo.org
Sat Aug 5 10:08:49 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.3.4
Component: buildbots | Version: 2.3.x
Keywords: |
Precise is being obsoleted which was the default travis was running on.
On around July 18th, travis changed default to run on trusty
https://blog.travis-ci.com/2017-07-11-trusty-as-default-linux-is-
coming?utm_source=web&utm_medium=banner&&utm_campaign=trusty-default
this is around when our travis build started failing.
I've forced 2.4. to run on precise at r15531 , but given precise is being
obsoleted soon, I think we need to migrate all our scripts to properly
work on trusty.
We might as well upgrade the PostgreSQL as well.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3803>
