[postgis-tickets] [PostGIS] #3803: travis needs to have script revised to work with trusty
PostGIS trac at osgeo.org
Mon Aug 7 13:34:44 PDT 2017
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 2.3.4
 Component:  buildbots  |    Version:  2.3.x
Resolution:             |   Keywords:
Comment (by strk):
 The failure seems related to PostgreSQL server user not having access to
 build dir:
 psql:/home/travis/build/postgis/postgis/regress/00-regress-
 install/share/contrib/postgis/postgis.sql:97: ERROR:  could not access
 file "/home/travis/build/postgis/postgis/regress/00-regress-
 install/lib/postgis-2.4": Permission denied
 Needs further inspection of directories permissions, can you try maybe to
 send a github PR adding these steps to .travis.yml:
  - ls -lR /home
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3803#comment:1>
