[postgis-tickets] r15535 - Formatting
Sandro Santilli
strk at kbt.io
Sun Aug 6 14:37:17 PDT 2017
Author: strk
Date: 2017-08-06 14:37:17 -0700 (Sun, 06 Aug 2017)
New Revision: 15535
trunk/NEWS
Formatting
Modified: trunk/NEWS
--- trunk/NEWS 2017-08-05 18:52:44 UTC (rev 15534)
+++ trunk/NEWS 2017-08-06 21:37:17 UTC (rev 15535)
@@ -16,16 +16,19 @@
- #3677, ST_FrechetDistance (Shinichi Sugiyama)
* Enhancements *
- Support for PostgreSQL 10
- #3747, Add zip4 and address_alphanumeric as attributes
to norm_addy tiger_geocoder type.
- #3748, address_standardizer lookup tables update
so pagc_normalize_address better standardizes abbreviations
PostGIS 2.4.0alpha
2017/08/05
See PostGIS 2.4.0 section for details
PostGIS 2.3.3
2017/07/01
@@ -59,6 +62,7 @@
- #3683, Unable to update postgis after postgres pg_upgrade going from < 9.5 to pg > 9.4
- #3688, ST_AsLatLonText: round minutes
PostGIS 2.3.1
2016/11/28
@@ -80,6 +84,8 @@
(Julien Rouhaud of Dalibo)
- #3667, geography ST_Segmentize bug
(Hugo Mercier of Oslandia)
PostGIS 2.3.0
2016/09/26
@@ -137,7 +143,9 @@
* Bug Fixes
- #2841, ST_MinimumBoundingCircle not covering original
* Performance Enhancements *
- #75, Enhancement to PIP short circuit (Dan Baston)
@@ -147,14 +155,17 @@
- Make adding a line to topology interruptible (Sandro Santilli)
- Documentation updates from Mike Toews
PostGIS 2.3.0rc1
2016/09/19
See PostGIS 2.3.0 section for details
PostGIS 2.3.0beta1
2016/09/06
PostGIS 2.2.2
2016/03/22
@@ -178,6 +189,7 @@
http://postgis.net/docs/manual-2.2/RT_FAQ.html#faq_raster_data_not_restore
- #3426, failing POINT EMPTY tests on fun architectures
PostGIS 2.2.1
2016/01/06
@@ -234,7 +246,6 @@
- Java binding moved to separate repository:
https://github.com/postgis/postgis-java
* Deprecated signatures *
- #2748, ST_Shift_Longitude renamed to ST_ShiftLongitude,
@@ -365,6 +376,7 @@
smaller files for ease of long-term maintenance and development
- #1220, lwerror and lwnotice function became internal to liblwgeom
PostGIS 2.1.8
2015/07/07
@@ -390,6 +402,7 @@
- #3088, Do not (re)define strcasestr in a liblwgeom.h
- #3094, Malformed GeoJSON inputs crash backend
PostGIS 2.1.6
2015/03/20
@@ -413,6 +426,7 @@
- #3020, ST_AddBand out-db bug where height using width value
- #3031, Allow restore of Geometry(Point) tables dumped with empties in them
PostGIS 2.1.5
2014/12/18
@@ -430,6 +444,7 @@
- #2953, 2D stats not generated when Z/M values are extreme
- #3009, Geography cast may effect underlying tuple
PostGIS 2.1.4
2014/09/10
