[postgis-tickets] r15547 - Fix travis build by changing permissions of home folder
Regina Obe lr at pcorp.us
Thu Aug 10 02:36:26 PDT 2017
Author: robe
Date: 2017-08-10 02:36:25 -0700 (Thu, 10 Aug 2017)
New Revision: 15547
   branches/2.3/.travis.yml
upgrade to test on 9.5
References #3803 for PostGIS 2.3.4
Closes https://github.com/postgis/postgis/pull/134
Modified: branches/2.3/.travis.yml
--- branches/2.3/.travis.yml	2017-08-08 23:48:01 UTC (rev 15546)
+++ branches/2.3/.travis.yml	2017-08-10 09:36:25 UTC (rev 15547)
@@ -3,12 +3,12 @@
     - RUNTESTFLAGS=-v
 addons:
-  postgresql: "9.4"
+  postgresql: "9.5"
 before_install:
   - sudo apt-get update -qq
   - sudo apt-get install -y
-      postgresql-9.4 postgresql-server-dev-9.4
+      postgresql-9.5 postgresql-server-dev-9.5
       build-essential autoconf libtool libcunit1-dev
       xsltproc docbook-xsl docbook-mathml dblatex
       libproj-dev libgdal1h libgdal-dev libgeos-dev libjson0-dev
@@ -22,6 +22,7 @@
 script:
   - ./configure
   - make
+  - find /home/travis -type d -exec chmod 755 {} \;
   - make check
   - make check RUNTESTFLAGS='--dumprestore'
   - sudo make install
