[postgis-tickets] r15548 - change back to using the default travis ci - trusty from precise
Regina Obe lr at pcorp.us
Thu Aug 10 02:55:56 PDT 2017
Author: robe
Date: 2017-08-10 02:55:56 -0700 (Thu, 10 Aug 2017)
New Revision: 15548
   trunk/.travis.yml
Put in place permissions to fix make check error
Closes #3803 for PostGIS 2.4
Modified: trunk/.travis.yml
--- trunk/.travis.yml	2017-08-10 09:36:25 UTC (rev 15547)
+++ trunk/.travis.yml	2017-08-10 09:55:56 UTC (rev 15548)
@@ -16,13 +16,13 @@
   - ./autogen.sh
 language: c
-dist: precise
 compiler: gcc
 script:
   - ./configure
   - make
+  - chmod 755 /home/travis
   - make check
   - make check RUNTESTFLAGS='--dumprestore'
   - sudo make install
