[postgis-tickets] [PostGIS] #3805: No way to create geography that croses -180..180 (date-line)
trac at osgeo.org
Mon Aug 14 06:18:20 PDT 2017
Reporter: OlegSerov | Owner: pramsey
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.3.4
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by OlegSerov):
Replying to [comment:1 pramsey]:
> The fact that the 3-space volumetric bounds of alaska and alberta
intersect (true) does not mean that the actual geographies do, as can be
seen by running the exact test.
> SELECT ST_Intersects(ST_GeogFromText('POLYGON((-116.614 61.7534,-109.804
> 61.7534,-109.804 57.5029,-116.614 57.5029,-116.614 61.7534))'),
> (ST_GeogFromText(' POLYGON((172.347846 71.441059,-173.233993
> 71.441059,-158.815832 71.441059,-144.397672 71.441059,-129.979511
> 71.441059,-129.979511 51.175092,-144.397672 51.175092,-158.815832
> 51.175092,-173.233993 51.175092,172.347846 51.175092,172.347846
> 71.441059))')));
> The && operator is not comparing the things you think. These aren't
squares drawn on a map, they are volumes in R3 that contain the shapes in
S2 described by your geographies. If you need a correct result, use the
actual ST_Intersects() function.
Please, direct me to the documentation / code where that is described.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3805#comment:4>
