[postgis-tickets] [PostGIS] #3471: Make install failed without complaining on linux
PostGIS trac at osgeo.org
Sat Aug 19 08:25:44 PDT 2017
  Reporter:  ehabets  |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:  wontfix  |   Keywords:
Changes (by dbaston):
 * status:  new => closed
 * resolution:   => wontfix
Comment:
 Discussed w/pramsey: conclusion is that we shouldn't require xsltproc just
 to build PostGIS, since it's only required for the make check step.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3471#comment:2>
