[postgis-tickets] r15561 - Update that yes indeed there are martian projectsions and you can even use them with geography to get measurements in meters instead of degrees.
Regina Obe
lr at pcorp.us
Sun Aug 20 07:43:36 PDT 2017
Author: robe
Date: 2017-08-20 07:43:36 -0700 (Sun, 20 Aug 2017)
New Revision: 15561
trunk/doc/using_postgis_dataman.xml
Closes #3637
Modified: trunk/doc/using_postgis_dataman.xml
--- trunk/doc/using_postgis_dataman.xml 2017-08-20 13:01:48 UTC (rev 15560)
+++ trunk/doc/using_postgis_dataman.xml 2017-08-20 14:43:36 UTC (rev 15561)
@@ -2321,11 +2321,15 @@
appropriate indexes are in place to provide good performance. The SRID of 312 used in these
examples is purely for demonstration. You should be using a REAL SRID listed in the the spatial_ref_sys table
and one that matches the projection of your data. If your data has no spatial reference system
- specified, you should be THINKING very thoughtfully why it doesn't and maybe it should.
- If your reason is because you are modeling something that doesn't have a geographic spatial reference system defined such as the internals of a molecule
- or a good location
- on Mars to transport the human race in the event of a nuclear holocaust,
- then simply leave out the SRID or make one up and insert it in the <varname>spatial_ref_sys</varname> table.</para>
+ specified, you should be THINKING very thoughtfully why it doesn't and maybe it should.</para>
+ <para>If your reason is because you are modeling something that doesn't have a geographic spatial reference system defined such as the internals of a molecule
+ or the floorplan of a not yet built amusement park then that's fine. If the location of the amusement park has been planned however, then it would make
+ sense to use a suitable planar coordinate system for that location if nothing more than to ensure the amusement part is not trespassing on already existing
+ structures.</para>
+ <para>Even in the case where you are planning a Mars expedition to transport the human race in the event of a nuclear holocaust
+and you want to map out the Mars planet for rehabitation, you can use a non-earthly coordinate system such as <ulink url="http://spatialreference.org/ref/iau2000/mars-2000/">Mars 2000</ulink>
+ make one up and insert it in the <varname>spatial_ref_sys</varname> table. Though this Mars coordinate system is a non-planar one (it's in degrees spheroidal),
+ you can use it with the geography type to have your length and proximity measurements in meters instead of degrees.</para>
<sect2>
<title>Taking Advantage of Indexes</title>
