[postgis-tickets] [PostGIS] #3637: Manual says there are not martian spatial reference systems but there are
PostGIS trac at osgeo.org
Sun Aug 20 07:43:37 PDT 2017
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  closed
  Priority:  blocker        |  Milestone:  PostGIS 2.4.0
 Component:  documentation  |    Version:  2.2.x
Resolution:  fixed          |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"15561" 15561]:
 #!CommitTicketReference repository="" revision="15561"
 Update that yes indeed there are martian projectsions and you can even use
 them with geography to get measurements in meters instead of degrees.
 Closes #3637
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3637#comment:5>
