[postgis-tickets] r15566 - Add support for curves in lwgeom_reverse/ST_Reverse
Sandro Santilli strk at kbt.io
Tue Aug 22 05:39:14 PDT 2017
Author: strk
Date: 2017-08-22 05:39:14 -0700 (Tue, 22 Aug 2017)
New Revision: 15566
Added:
   trunk/regress/reverse.sql
   trunk/regress/reverse_expected
   trunk/NEWS
   trunk/doc/reference_editor.xml
   trunk/liblwgeom/liblwgeom_internal.h
   trunk/liblwgeom/lwgeom.c
   trunk/regress/Makefile.in
Includes tests
Closes #2411
Modified: trunk/NEWS
--- trunk/NEWS	2017-08-22 12:38:59 UTC (rev 15565)
+++ trunk/NEWS	2017-08-22 12:39:14 UTC (rev 15566)
@@ -3,6 +3,7 @@
  * New Features *
+  - #2411, curves support in ST_Reverse (Sandro Santilli)
   - #2951, ST_Centroid for geography (Danny Götte)
   - #3788, Allow postgis_restore.pl to work on directory-style (-Fd) dumps
            (Roger Crew)
Modified: trunk/doc/reference_editor.xml
--- trunk/doc/reference_editor.xml	2017-08-22 12:38:59 UTC (rev 15565)
+++ trunk/doc/reference_editor.xml	2017-08-22 12:39:14 UTC (rev 15566)
@@ -1120,6 +1120,10 @@
 		<title>Description</title>
 		<para>Can be used on any geometry and reverses the order of the vertexes.</para>
+		<para>Enhanced: 2.4.0 support for curves was introduced.</para>
+		<para>&Z_support;</para>
+		<para>&P_support;</para>
 	  </refsection>
 	  <refsection>
Modified: trunk/liblwgeom/liblwgeom_internal.h
--- trunk/liblwgeom/liblwgeom_internal.h	2017-08-22 12:38:59 UTC (rev 15565)
+++ trunk/liblwgeom/liblwgeom_internal.h	2017-08-22 12:39:14 UTC (rev 15566)
@@ -341,6 +341,11 @@
 GBOX *gbox_clone(const GBOX *gbox);
+ * Reverse
+extern void lwcircstring_reverse(LWCIRCSTRING *curve);
 * Startpoint
 int lwpoly_startpoint(const LWPOLY* lwpoly, POINT4D* pt);
Modified: trunk/liblwgeom/lwgeom.c
--- trunk/liblwgeom/lwgeom.c	2017-08-22 12:38:59 UTC (rev 15565)
+++ trunk/liblwgeom/lwgeom.c	2017-08-22 12:39:14 UTC (rev 15566)
@@ -106,11 +106,18 @@
 	case TRIANGLETYPE:
 		lwtriangle_reverse((LWTRIANGLE *)lwgeom);
 		return;
+	case CIRCSTRINGTYPE:
+		lwcircstring_reverse((LWCIRCSTRING *)lwgeom);
+		return;
+	case MULTICURVETYPE:
 	case MULTILINETYPE:
 	case MULTIPOLYGONTYPE:
+	case MULTISURFACETYPE:
 	case POLYHEDRALSURFACETYPE:
 	case TINTYPE:
 	case COLLECTIONTYPE:
+	case COMPOUNDTYPE:
+	case CURVEPOLYTYPE:
 		col = (LWCOLLECTION *)lwgeom;
 		for (i=0; i<col->ngeoms; i++)
 			lwgeom_reverse(col->geoms[i]);
Modified: trunk/regress/Makefile.in
--- trunk/regress/Makefile.in	2017-08-22 12:38:59 UTC (rev 15565)
+++ trunk/regress/Makefile.in	2017-08-22 12:39:14 UTC (rev 15566)
@@ -123,6 +123,7 @@
 	relate \
 	remove_repeated_points \
 	removepoint \
+	reverse \
 	setpoint \
 	simplify \
 	simplifyvw \
Added: trunk/regress/reverse.sql
--- trunk/regress/reverse.sql	                        (rev 0)
+++ trunk/regress/reverse.sql	2017-08-22 12:39:14 UTC (rev 15566)
@@ -0,0 +1,98 @@
+-- Point
+SELECT 'pnt1', ST_AsText(ST_Reverse('POINT EMPTY'::geometry));
+SELECT 'pnt2', ST_AsText(ST_Reverse('POINT(0 0)'::geometry));
+-- Multipoint
+SELECT 'mpnt1', ST_AsText(ST_Reverse('MULTIPOINT EMPTY'::geometry));
+SELECT 'mpnt2', ST_AsText(ST_Reverse('MULTIPOINT(0 0)'::geometry));
+SELECT 'mpnt3', ST_AsText(ST_Reverse('MULTIPOINT(0 0,1 1)'::geometry));
+-- Linestring
+SELECT 'lin1', ST_AsText(ST_Reverse('LINESTRING EMPTY'::geometry));
+SELECT 'lin2', ST_AsText(ST_Reverse('LINESTRING(0 0, 1 1)'::geometry));
+SELECT 'lin2m', ST_AsText(ST_Reverse('LINESTRING M (0 0 3,1 1 6)'::geometry));
+SELECT 'lin2z', ST_AsText(ST_Reverse('LINESTRING Z (0 0 3,1 1 6)'::geometry));
+-- MultiLinestring
+SELECT 'mlin1', ST_AsText(ST_Reverse('MULTILINESTRING EMPTY'::geometry));
+SELECT 'mlin2', ST_AsText(ST_Reverse('MULTILINESTRING((0 0, 1 0),(2 0, -3 3))'::geometry));
+SELECT 'mlin2m', ST_AsText(ST_Reverse('MULTILINESTRING M ((0 0 5, 1 0 3),(2 0 2, -3 3 1))'::geometry));
+SELECT 'mlin2z', ST_AsText(ST_Reverse('MULTILINESTRING Z ((0 0 5, 1 0 3),(2 0 2, -3 3 1))'::geometry));
+-- Polygon
+SELECT 'plg1', ST_AsText(ST_Reverse('POLYGON EMPTY'::geometry));
+SELECT 'plg2', ST_AsText(ST_Reverse('POLYGON((0 0,8 0,8 8,0 8,0 0),(2 2,2 4,4 4,4 2,2 2))'::geometry));
+SELECT 'plg2m', ST_AsText(ST_Reverse('POLYGON M ((0 0 9,8 0 8,8 8 7,0 8 8,0 0 9),(2 2 1,2 4 2,4 4 3,4 2 2,2 2 1))'::geometry));
+SELECT 'plg2z', ST_AsText(ST_Reverse('POLYGON Z ((0 0 9,8 0 8,8 8 7,0 8 8,0 0 9),(2 2 1,2 4 2,4 4 3,4 2 2,2 2 1))'::geometry));
+-- MultiPolygon
+SELECT 'mplg1', ST_AsText(ST_Reverse('MULTIPOLYGON EMPTY'::geometry));
+SELECT 'mplg2', ST_AsText(ST_Reverse('MULTIPOLYGON(((0 0,5 0,5 5,0 5,0 0),(2 2,2 4,4 4,4 2,2 2)),((6 6,7 6,7 7,6 6)))'::geometry));
+SELECT 'mplg2m', ST_AsText(ST_Reverse('MULTIPOLYGON M (((0 0 1,5 0 2,5 5 3,0 5 4,0 0 1),(2 2 0,2 4 1,4 4 2,4 2 3,2 2 0)),((6 6 2,7 6 4,7 7 6,6 6 2)))'::geometry));
+SELECT 'mplg2z', ST_AsText(ST_Reverse('MULTIPOLYGON Z (((0 0 1,5 0 2,5 5 3,0 5 4,0 0 1),(2 2 0,2 4 1,4 4 2,4 2 3,2 2 0)),((6 6 2,7 6 4,7 7 6,6 6 2)))'::geometry));
+-- CircularString
+SELECT 'cstr1', ST_AsText(ST_Reverse('CIRCULARSTRING EMPTY'::geometry));
+SELECT 'cstr2', ST_AsText(ST_Reverse('CIRCULARSTRING(0 0,1 1,2 0,3 -1,4 0)'::geometry));
+SELECT 'cstr2m', ST_AsText(ST_Reverse('CIRCULARSTRING M (0 0 1,1 1 2,2 0 3,3 -1 4,4 0 5)'::geometry));
+SELECT 'cstr2z', ST_AsText(ST_Reverse('CIRCULARSTRING Z (0 0 1,1 1 2,2 0 3,3 -1 4,4 0 5)'::geometry));
+-- CompoundCurve
+SELECT 'ccrv1', ST_AsText(ST_Reverse('COMPOUNDCURVE EMPTY'::geometry));
+SELECT 'ccrv2', ST_AsText(ST_Reverse('COMPOUNDCURVE(CIRCULARSTRING(0 0,1 1,1 0),(1 0,0 1))'::geometry));
+SELECT 'ccrv2m', ST_AsText(ST_Reverse('COMPOUNDCURVE M (CIRCULARSTRING(0 0 3,1 1 2,1 0 1),(1 0 6,0 1 7))'::geometry));
+SELECT 'ccrv2z', ST_AsText(ST_Reverse('COMPOUNDCURVE Z (CIRCULARSTRING(0 0 3,1 1 2,1 0 1),(1 0 6,0 1 7))'::geometry));
+-- CurvePolygon
+SELECT 'cplg1', ST_AsText(ST_Reverse('CURVEPOLYGON EMPTY'::geometry));
+SELECT 'cplg2', ST_AsText(ST_Reverse('CURVEPOLYGON (COMPOUNDCURVE (CIRCULARSTRING (0 0,1 1,1 0),(1 0,0 1),(0 1,0 0)))'::geometry));
+SELECT 'cplg2m', ST_AsText(ST_Reverse('CURVEPOLYGON M (COMPOUNDCURVE (CIRCULARSTRING (0 0 2,1 1 2,1 0 2),(1 0 2,0 1 2),(0 1 2, 0 0 2)))'::geometry));
+SELECT 'cplg2z', ST_AsText(ST_Reverse('CURVEPOLYGON Z (COMPOUNDCURVE (CIRCULARSTRING (0 0 2,1 1 2,1 0 2),(1 0 2,0 1 2),(0 1 2, 0 0 2)))'::geometry));
+-- MultiCurve
+SELECT 'mc1', ST_AsText(ST_Reverse('MULTICURVE EMPTY'::geometry));
+SELECT 'mc2', ST_AsText(ST_Reverse('MULTICURVE ((5 5, 3 5, 3 3, 0 3), CIRCULARSTRING (0 0, 0.2 1, 0.5 1.4), COMPOUNDCURVE (CIRCULARSTRING (0 0,1 1,1 0),(1 0,0 1)))'::geometry));
+SELECT 'mc2zm', ST_AsText(ST_Reverse('MULTICURVE ZM ((5 5 0 1, 3 5 2 3, 3 3 7 5, 0 3 9 8), CIRCULARSTRING (0 0 1 3, 0.2 1 4 2, 0.5 1.4 5 1), COMPOUNDCURVE (CIRCULARSTRING (0 0 -1 -2,1 1 0 4,1 0 5 6),(1 0 4 2,0 1 3 4)))'::geometry));
+-- MultiSurface
+SELECT 'ms1', ST_AsText(ST_Reverse('MULTISURFACE EMPTY'::geometry));
+SELECT 'ms2', ST_AsText(ST_Reverse('MULTISURFACE (CURVEPOLYGON (CIRCULARSTRING (-2 0, -1 -1, 0 0, 1 -1, 2 0, 0 2, -2 0), (-1 0, 0 0.5, 1 0, 0 1, -1 0)), ((7 8, 10 10, 6 14, 4 11, 7 8)))'::geometry));
+SELECT 'ms2m', ST_AsText(ST_Reverse(
+'MULTISURFACE M (CURVEPOLYGON M (CIRCULARSTRING M (-2 0 0, -1 -1 1, 0 0 2, 1 -1 3, 2 0 4, 0 2 2, -2 0 0), (-1 0 1, 0 0.5 2, 1 0 3, 0 1 3, -1 0 1)), ((7 8 7, 10 10 5, 6 14 3, 4 11 4, 7 8 7)))'
+::geometry));
+SELECT 'ms2z', ST_AsText(ST_Reverse(
+'MULTISURFACE Z (CURVEPOLYGON Z (CIRCULARSTRING Z (-2 0 0, -1 -1 1, 0 0 2, 1 -1 3, 2 0 4, 0 2 2, -2 0 0), (-1 0 1, 0 0.5 2, 1 0 3, 0 1 3, -1 0 1)), ((7 8 7, 10 10 5, 6 14 3, 4 11 4, 7 8 7)))'
+::geometry));
+-- PolyedralSurface (TODO)
+SELECT 'ps1', ST_AsText(ST_Reverse(
+'POLYHEDRALSURFACE EMPTY'
+::geometry));
+SELECT 'ps2', ST_AsText(ST_Reverse(
+'POLYHEDRALSURFACE (((0 0,0 0,0 1,0 0)),((0 0,0 1,1 0,0 0)),((0 0,1 0,0 0,0 0)),((1 0,0 1,0 0,1 0)))'
+::geometry));
+-- Triangle
+SELECT 'tri1', ST_AsText(ST_Reverse(
+'TRIANGLE EMPTY'
+::geometry));
+SELECT 'tri2', ST_AsText(ST_Reverse(
+'TRIANGLE ((1 2,4 5,7 8,1 2))'
+::geometry));
+SELECT 'tri2z', ST_AsText(ST_Reverse(
+'TRIANGLE Z ((1 2 3,4 5 6,7 8 9,1 2 3))'
+::geometry));
+-- TIN
+SELECT 'tin1', ST_AsText(ST_Reverse( 'TIN EMPTY' ::geometry));
+SELECT 'tin2', ST_AsText(ST_Reverse(
+'TIN ( ((0 0, 0 0, 0 1, 0 0)), ((0 0, 0 1, 1 1, 0 0)) )'
+::geometry));
+-- GeometryCollection
+SELECT 'gc1', ST_AsText(ST_Reverse(
+'GEOMETRYCOLLECTION EMPTY'
+::geometry));
+SELECT 'gc2', ST_AsText(ST_Reverse(
+'GEOMETRYCOLLECTION(MULTIPOLYGON(((0 0,10 0,10 10,0 10,0 0),(2 2,2 5,5 5,5 2,2 2))),POINT(0 0),MULTILINESTRING((0 0, 2 0),(1 1, 2 2)))'
+::geometry));
Added: trunk/regress/reverse_expected
--- trunk/regress/reverse_expected	                        (rev 0)
+++ trunk/regress/reverse_expected	2017-08-22 12:39:14 UTC (rev 15566)
@@ -0,0 +1,49 @@
+pnt1|POINT EMPTY
+pnt2|POINT(0 0)
+mpnt1|MULTIPOINT EMPTY
+mpnt2|MULTIPOINT(0 0)
+mpnt3|MULTIPOINT(0 0,1 1)
+lin1|LINESTRING EMPTY
+lin2|LINESTRING(1 1,0 0)
+lin2m|LINESTRING M (1 1 6,0 0 3)
+lin2z|LINESTRING Z (1 1 6,0 0 3)
+mlin1|MULTILINESTRING EMPTY
+mlin2|MULTILINESTRING((1 0,0 0),(-3 3,2 0))
+mlin2m|MULTILINESTRING M ((1 0 3,0 0 5),(-3 3 1,2 0 2))
+mlin2z|MULTILINESTRING Z ((1 0 3,0 0 5),(-3 3 1,2 0 2))
+plg1|POLYGON EMPTY
+plg2|POLYGON((0 0,0 8,8 8,8 0,0 0),(2 2,4 2,4 4,2 4,2 2))
+plg2m|POLYGON M ((0 0 9,0 8 8,8 8 7,8 0 8,0 0 9),(2 2 1,4 2 2,4 4 3,2 4 2,2 2 1))
+plg2z|POLYGON Z ((0 0 9,0 8 8,8 8 7,8 0 8,0 0 9),(2 2 1,4 2 2,4 4 3,2 4 2,2 2 1))
+mplg1|MULTIPOLYGON EMPTY
+mplg2|MULTIPOLYGON(((0 0,0 5,5 5,5 0,0 0),(2 2,4 2,4 4,2 4,2 2)),((6 6,7 7,7 6,6 6)))
+mplg2m|MULTIPOLYGON M (((0 0 1,0 5 4,5 5 3,5 0 2,0 0 1),(2 2 0,4 2 3,4 4 2,2 4 1,2 2 0)),((6 6 2,7 7 6,7 6 4,6 6 2)))
+mplg2z|MULTIPOLYGON Z (((0 0 1,0 5 4,5 5 3,5 0 2,0 0 1),(2 2 0,4 2 3,4 4 2,2 4 1,2 2 0)),((6 6 2,7 7 6,7 6 4,6 6 2)))
+cstr1|CIRCULARSTRING EMPTY
+cstr2|CIRCULARSTRING(4 0,3 -1,2 0,1 1,0 0)
+cstr2m|CIRCULARSTRING M (4 0 5,3 -1 4,2 0 3,1 1 2,0 0 1)
+cstr2z|CIRCULARSTRING Z (4 0 5,3 -1 4,2 0 3,1 1 2,0 0 1)
+ccrv1|COMPOUNDCURVE EMPTY
+ccrv2|COMPOUNDCURVE(CIRCULARSTRING(1 0,1 1,0 0),(0 1,1 0))
+ccrv2m|COMPOUNDCURVE M (CIRCULARSTRING M (1 0 1,1 1 2,0 0 3),(0 1 7,1 0 6))
+ccrv2z|COMPOUNDCURVE Z (CIRCULARSTRING Z (1 0 1,1 1 2,0 0 3),(0 1 7,1 0 6))
+cplg1|CURVEPOLYGON EMPTY
+cplg2|CURVEPOLYGON(COMPOUNDCURVE(CIRCULARSTRING(1 0,1 1,0 0),(0 1,1 0),(0 0,0 1)))
+cplg2m|CURVEPOLYGON M (COMPOUNDCURVE M (CIRCULARSTRING M (1 0 2,1 1 2,0 0 2),(0 1 2,1 0 2),(0 0 2,0 1 2)))
+cplg2z|CURVEPOLYGON Z (COMPOUNDCURVE Z (CIRCULARSTRING Z (1 0 2,1 1 2,0 0 2),(0 1 2,1 0 2),(0 0 2,0 1 2)))
+mc1|MULTICURVE EMPTY
+mc2|MULTICURVE((0 3,3 3,3 5,5 5),CIRCULARSTRING(0.5 1.4,0.2 1,0 0),COMPOUNDCURVE(CIRCULARSTRING(1 0,1 1,0 0),(0 1,1 0)))
+mc2zm|MULTICURVE ZM ((0 3 9 8,3 3 7 5,3 5 2 3,5 5 0 1),CIRCULARSTRING ZM (0.5 1.4 5 1,0.2 1 4 2,0 0 1 3),COMPOUNDCURVE ZM (CIRCULARSTRING ZM (1 0 5 6,1 1 0 4,0 0 -1 -2),(0 1 3 4,1 0 4 2)))
+ms1|MULTISURFACE EMPTY
+ms2|MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(-2 0,0 2,2 0,1 -1,0 0,-1 -1,-2 0),(-1 0,0 1,1 0,0 0.5,-1 0)),((7 8,4 11,6 14,10 10,7 8)))
+ms2m|MULTISURFACE M (CURVEPOLYGON M (CIRCULARSTRING M (-2 0 0,0 2 2,2 0 4,1 -1 3,0 0 2,-1 -1 1,-2 0 0),(-1 0 1,0 1 3,1 0 3,0 0.5 2,-1 0 1)),((7 8 7,4 11 4,6 14 3,10 10 5,7 8 7)))
+ms2z|MULTISURFACE Z (CURVEPOLYGON Z (CIRCULARSTRING Z (-2 0 0,0 2 2,2 0 4,1 -1 3,0 0 2,-1 -1 1,-2 0 0),(-1 0 1,0 1 3,1 0 3,0 0.5 2,-1 0 1)),((7 8 7,4 11 4,6 14 3,10 10 5,7 8 7)))
+ps1|POLYHEDRALSURFACE EMPTY
+ps2|POLYHEDRALSURFACE(((0 0,0 1,0 0,0 0)),((0 0,1 0,0 1,0 0)),((0 0,0 0,1 0,0 0)),((1 0,0 0,0 1,1 0)))
+tri1|TRIANGLE EMPTY
+tri2|TRIANGLE((1 2,7 8,4 5,1 2))
+tri2z|TRIANGLE Z ((1 2 3,7 8 9,4 5 6,1 2 3))
+tin1|TIN EMPTY
+tin2|TIN(((0 0,0 1,0 0,0 0)),((0 0,1 1,0 1,0 0)))
+gc1|GEOMETRYCOLLECTION EMPTY
+gc2|GEOMETRYCOLLECTION(MULTIPOLYGON(((0 0,0 10,10 10,10 0,0 0),(2 2,5 2,5 5,2 5,2 2))),POINT(0 0),MULTILINESTRING((2 0,0 0),(2 2,1 1)))
