[postgis-tickets] r15567 - update to use more efficient lateral syntax
Regina Obe lr at pcorp.us
Tue Aug 22 07:43:42 PDT 2017
Author: robe
Date: 2017-08-22 07:43:42 -0700 (Tue, 22 Aug 2017)
New Revision: 15567
   trunk/doc/reference_raster.xml
Modified: trunk/doc/reference_raster.xml
--- trunk/doc/reference_raster.xml	2017-08-22 12:39:14 UTC (rev 15566)
+++ trunk/doc/reference_raster.xml	2017-08-22 14:43:42 UTC (rev 15567)
@@ -2000,7 +2000,7 @@
                     <para>Create 16 tiles in a 4x4 grid to cover the WGS84 area from upper left corner (22, 77) to lower right corner (55, 33).</para>
                     <programlisting><![CDATA[SELECT (ST_MetaData(tile)).* FROM ST_MakeEmptyCoverage(1, 1, 4, 4, 22, 33, (55 - 22)/(4)::float, (33 - 77)/(4)::float, 0., 0., 4326) tile;
- upperleftx | upperlefty | width | height | scalex | scaley | skewx | skewy | srid | numbands
+ upperleftx | upperlefty | width | height | scalex | scaley | skewx | skewy | srid | numbands
          22 |         33 |     1 |      1 |   8.25 |    -11 |     0 |     0 | 4326 |        0
       30.25 |         33 |     1 |      1 |   8.25 |    -11 |     0 |     0 | 4326 |        0
@@ -4429,8 +4429,9 @@
 			<refsection>
 				<title>Examples</title>
-				<programlisting>
-SELECT x, y, val, ST_AsText(geom) FROM (SELECT (ST_PixelAsCentroids(rast, 1)).* FROM dummy_rast WHERE rid = 2) foo;
+				<programlisting> --LATERAL syntax requires PostgreSQL 9.3+
+SELECT x, y, val, ST_AsText(geom)
+	FROM (SELECT dp.* FROM dummy_rast, LATERAL ST_PixelAsCentroids(rast, 1) AS dp WHERE rid = 2) foo;
  x | y | val |           st_astext
  1 | 1 | 253 | POINT(3427927.775 5793243.975)
@@ -12918,11 +12919,11 @@
 			  <refsection>
-					<programlisting>
+					<programlisting> -- this syntax requires PostgreSQL 9.3+
 SELECT val, ST_AsText(geom) As geomwkt
 FROM (
-SELECT (ST_DumpAsPolygons(rast)).*
-FROM dummy_rast
+SELECT dp.*
+FROM dummy_rast, LATERAL ST_DumpAsPolygons(rast) AS dp
 WHERE rid = 2
 ) As foo
 WHERE val BETWEEN 249 and 251
