[postgis-tickets] [PostGIS] #3812: Changed 2" isn't numeric
trac at osgeo.org
Tue Aug 22 16:07:21 PDT 2017
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.0
Component: postgis | Version: 2.3.x
Keywords: |
I've noticed a couple of warnings upon generating postgis_upgrade.pl:
Argument "2\n-- Changed 2" isn't numeric in addition (+) at
../utils/postgis_proc_upgrade.pl line 105, <INPUT> line 3883.
../utils/postgis_proc_upgrade.pl line 105, <INPUT> line 3892.
These are due to a regexp assuming that above SQL objects you only find
comments with a given version pattern:
.*(?:Availability|Changed|Updated):\s([^\.])\.([^.]*)
That is, Availability or Changed or Updated followed by a colon.
Two comments broke the assumption:
-- Availability: 2.2
-- Changed 2.4.0: marked parallel safe
And:
In other places the format was correct, like here:
-- Availability: 1.2.2
-- Changed: 2.4.0 marked parallel safe
CREATE AGGREGATE ST_Accum (geometry) (
The upgrade script will generate DROP and CREATE based on that
information, so these errors should result in non-parallel safe aggregates
on upgrade.
It's a blocker.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3812>
