[postgis-tickets] [PostGIS] #3814: Can't compile against PostgreSQL 11 head
PostGIS trac at osgeo.org
Tue Aug 22 18:49:56 PDT 2017
 Reporter:  robe      |      Owner:  robe
     Type:  defect    |     Status:  assigned
 Priority:  critical  |  Milestone:  PostGIS 2.4.0
Component:  postgis   |    Version:  trunk
 Keywords:            |
 Hmm looks like they changed something in PostgreSQL 11 branch about a day
 ago that is causing Debbie to scream.  They must have also flipped the
 branch to PostgreSQL 11 so we've been testing PostgreSQL 11 instead of
 PostgreSQL 10 for at least a couple of days.
 Debbie's breaking on compiling MVT.
 https://debbie.postgis.net/job/PostGIS_Regress/6144/console
  -------------- Compiler Info -------------
   C compiler:           gcc -g -O2
   SQL preprocessor:     /usr/bin/cpp -traditional-cpp -w -P
  -------------- Dependencies --------------
   GEOS config:
 /var/lib/jenkins/workspace/geos/rel-3.7.0devw64/bin/geos-config
   GEOS version:         3.7.0dev
   GDAL config:          /var/lib/jenkins/workspace/gdal/rel-2.1w64/bin
 /gdal-config
   GDAL version:         2.1.4
   SFCGAL config:        /usr/bin/sfcgal-config
   SFCGAL version:       1.3.0
   PostgreSQL config:
 /var/lib/jenkins/workspace/pg/rel/pg10.0w64/bin/pg_config
   PostgreSQL version:   PostgreSQL 11devel
   PROJ4 version:        49
   Libxml2 config:       /usr/bin/xml2-config
   Libxml2 version:      2.9.4
   JSON-C support:       yes
   protobuf-c support:   yes
   PCRE support:         yes
   PostGIS debug level:  0
   Perl:                 /usr/bin/perl
  --------------- Extensions ---------------
   PostGIS Raster:       enabled
   PostGIS Topology:     enabled
   SFCGAL support:       enabled
   Address Standardizer support:       enabled
  -------- Documentation Generation --------
   xsltproc:             /usr/bin/xsltproc
   xsl style sheets:     /usr/share/xml/docbook/stylesheet/docbook-xsl
   dblatex:              /usr/bin/dblatex
   convert:              /usr/bin/convert
   mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
 /workspace/pg/rel/pg10.0w64/include/postgresql/internal  -D_GNU_SOURCE
 -c -o mvt.o mvt.c
 mvt.c: In function ‘parse_column_keys’:
 mvt.c:307:45: error: invalid type argument of ‘->’ (have
 ‘FormData_pg_attribute {aka struct FormData_pg_attribute}’)
    Oid typoid = getBaseType(tupdesc->attrs[i]->atttypid);
 mvt.c:312:33: error: invalid type argument of ‘->’ (have
    char *tkey = tupdesc->attrs[i]->attname.data;
 mvt.c: In function ‘parse_values’:
 mvt.c:553:32: error: invalid type argument of ‘->’ (have
    char *key = tupdesc->attrs[i]->attname.data;
 mvt.c:555:45: error: invalid type argument of ‘->’ (have
 <builtin>: recipe for target 'mvt.o' failed
 make[1]: *** [mvt.o] Error 1
 make[1]: Leaving directory
 '/var/lib/jenkins/workspace/postgis/branches/2.4/postgis'
 GNUmakefile:16: recipe for target 'all' failed
 make: *** [all] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3814>
