[postgis-tickets] [PostGIS] #3647: non-noded intersection error when running st_node
PostGIS trac at osgeo.org
Wed Aug 23 09:16:41 PDT 2017
  Reporter:  mathiasversichele  |      Owner:  robe
      Type:  defect             |     Status:  closed
  Priority:  blocker            |  Milestone:  PostGIS 2.4.0
 Component:  postgis            |    Version:  2.2.x
Resolution:  fixed              |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"15571" 15571]:
 #!CommitTicketReference repository="" revision="15571"
 Reduce likeliness of non-noded intersections when using ST_Node
 Patch contributed by Wouter Geraedts (with minor adjustments to the doc)
 Closes #3647
 Closes ​https://github.com/postgis/postgis/pull/136
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3647#comment:11>
