[postgis-tickets] r15580 - Fix census tabblock download and document process for including it.
Regina Obe
lr at pcorp.us
Wed Aug 23 20:56:41 PDT 2017
Author: robe
Date: 2017-08-23 20:56:41 -0700 (Wed, 23 Aug 2017)
New Revision: 15580
trunk/doc/extras_tigergeocoder.xml
trunk/doc/installation.xml
trunk/extras/tiger_geocoder/tiger_loader_2016.sql
Reference #3698 for PostGIS 2.4.0
Change site of census
Reference #3816 for PostGIS 2.4.0
Modified: trunk/doc/extras_tigergeocoder.xml
--- trunk/doc/extras_tigergeocoder.xml 2017-08-24 03:00:07 UTC (rev 15579)
+++ trunk/doc/extras_tigergeocoder.xml 2017-08-24 03:56:41 UTC (rev 15580)
@@ -512,6 +512,12 @@
<title>Description</title>
<para>Given a geometry will return the census tract location of that geometry. NAD 83 long lat is assumed if no spatial ref sys is specified.</para>
+ <note><para>This function uses the census <varname>tract</varname> whic is not loaded by default. If you have already loaded your state table, you can load tract
+ as well as bg, and tabblock using the <xref linkend="Loader_Generate_Census_Script" /> script.</para>
+ <para>If you have not loaded your state data yet and want these additional tables loaded, do the following</para>
+ <programlisting>UPDATE tiger.loader_lookuptables SET load = true WHERE load = false AND lookup_name IN('tract', 'bg', 'tabblock');</programlisting>
+ <para>then they will be included by the <xref linkend="Loader_Generate_Script" />.</para>
+ </note>
<para>Availability: 2.0.0</para>
Modified: trunk/doc/installation.xml
--- trunk/doc/installation.xml 2017-08-24 03:00:07 UTC (rev 15579)
+++ trunk/doc/installation.xml 2017-08-24 03:56:41 UTC (rev 15580)
@@ -1603,8 +1603,13 @@
</screen>
</listitem>
- <listitem><para>For each state you want to load data for, generate a state script <xref linkend="Loader_Generate_Script" />. DO NOT Generate the state script until you have already loaded the nation data, because the state script utilizes county list loaded by nation script.</para></listitem>
+ <listitem><para>By default the tables corresponding to <varname>bg</varname>, <varname>tract</varname>, <varname>tabblock</varname> are not loaded. Thse tables are not used by the geocoder but are used by folks for population statistics.
+ If you wish to load them as part of your state loads, run the following statement to enable them.</para>
+ <para>Alternatively you can load just these tables after loading state data using the <xref linkend="Loader_Generate_Census_Script" /></para></listitem>
+ <listitem><para>For each state you want to load data for, generate a state script <xref linkend="Loader_Generate_Script" />.</para><warning><para>DO NOT Generate the state script until you have already loaded the nation data, because the state script utilizes county list loaded by nation script.</para></warning></listitem>
<listitem><programlisting>psql -c "SELECT Loader_Generate_Script(ARRAY['MA'], 'debbie')" -d geocoder -tA > /gisdata/ma_load.sh</programlisting></listitem>
<listitem><para>Run the generated commandline scripts.</para>
Modified: trunk/extras/tiger_geocoder/tiger_loader_2016.sql
--- trunk/extras/tiger_geocoder/tiger_loader_2016.sql 2017-08-24 03:00:07 UTC (rev 15579)
+++ trunk/extras/tiger_geocoder/tiger_loader_2016.sql 2017-08-24 03:56:41 UTC (rev 15580)
@@ -42,7 +42,7 @@
CONSTRAINT enforce_geotype_geom CHECK (geometrytype(the_geom) = 'MULTIPOLYGON'::text OR the_geom IS NULL),
CONSTRAINT enforce_srid_geom CHECK (st_srid(the_geom) = 4269)
DROP TABLE IF EXISTS tiger.tabblock;
CREATE TABLE tabblock
@@ -221,7 +221,7 @@
TRUNCATE TABLE loader_variables;
INSERT INTO loader_variables(tiger_year, website_root , staging_fold, data_schema, staging_schema)
- VALUES('2016', 'http://www2.census.gov/geo/tiger/TIGER2016', '/gisdata', 'tiger_data', 'tiger_staging');
+ VALUES('2016', 'https://www2.census.gov/geo/tiger/TIGER2016', '/gisdata', 'tiger_data', 'tiger_staging');
GRANT SELECT ON TABLE loader_variables TO public;
DO $$
@@ -243,9 +243,9 @@
TRUNCATE TABLE loader_lookuptables;
GRANT SELECT ON TABLE loader_lookuptables TO public;
-- put in explanatory comments of what each column is for
COMMENT ON COLUMN loader_lookuptables.lookup_name IS 'This is the table name to inherit from and suffix of resulting output table -- how the table will be named -- edges here would mean -- ma_edges , pa_edges etc. except in the case of national tables. national level tables have no prefix';
COMMENT ON COLUMN loader_lookuptables.level_nation IS 'These are tables that contain all data for the whole US so there is just a single file';
@@ -263,16 +263,16 @@
${psql} -c "ALTER TABLE ${data_schema}.${state_abbrev}_${lookup_name} ADD CONSTRAINT chk_statefp CHECK (statefp = ''${state_fips}'');"', ARRAY['gid']);
INSERT INTO loader_lookuptables(process_order, lookup_name, table_name, load, level_county, level_state, single_geom_mode, insert_mode, pre_load_process, post_load_process, columns_exclude )
-VALUES(11, 'tabblock', 'tabblock', false, false, true,false, 'c',
+VALUES(11, 'tabblock', 'tabblock10', false, false, true,false, 'c',
'${psql} -c "CREATE TABLE ${data_schema}.${state_abbrev}_${lookup_name}(CONSTRAINT pk_${state_abbrev}_${lookup_name} PRIMARY KEY (tabblock_id)) INHERITS(tiger.${lookup_name});" ',
-'${psql} -c "ALTER TABLE ${staging_schema}.${state_abbrev}_${lookup_name} RENAME geoid10 TO tabblock_id;"
+'${psql} -c "ALTER TABLE ${staging_schema}.${state_abbrev}_${lookup_name} RENAME geoid10 TO tabblock_id; SELECT loader_load_staged_data(lower(''${state_abbrev}_${table_name}''), lower(''${state_abbrev}_${lookup_name}'')); "
${psql} -c "CREATE INDEX ${data_schema}_${state_abbrev}_${lookup_name}_the_geom_gist ON ${data_schema}.${state_abbrev}_${lookup_name} USING gist(the_geom);"
-${psql} -c "vacuum analyze ${data_schema}.${state_abbrev}_${lookup_name};"', '{gid, uatyp10, uatype, tractce10, blockce10,suffix1ce,blockce,tractce}'::text[]);
+${psql} -c "vacuum analyze ${data_schema}.${state_abbrev}_${lookup_name};"', '{gid, uatyp10, uatype, suffix1ce}'::text[]);
-VALUES(12, 'bg', 'bg', true,false, true,false, 'c',
+VALUES(12, 'bg', 'bg', false,false, true,false, 'c',
'${psql} -c "CREATE TABLE ${data_schema}.${state_abbrev}_${lookup_name}(CONSTRAINT pk_${state_abbrev}_${lookup_name} PRIMARY KEY (bg_id)) INHERITS(tiger.${lookup_name});" ',
'${psql} -c "ALTER TABLE ${staging_schema}.${state_abbrev}_${table_name} RENAME geoid TO bg_id; SELECT loader_load_staged_data(lower(''${state_abbrev}_${table_name}''), lower(''${state_abbrev}_${lookup_name}'')); "
@@ -289,7 +289,7 @@
${psql} -c "VACUUM ANALYZE ${data_schema}.${lookup_name};"
${psql} -c "INSERT INTO ${data_schema}.${lookup_name}_lookup(st_code, state, co_code, name) SELECT CAST(s.statefp as integer), s.abbrev, CAST(c.countyfp as integer), c.name FROM ${data_schema}.${lookup_name} As c INNER JOIN state_lookup As s ON s.statefp = c.statefp;"
${psql} -c "VACUUM ANALYZE ${data_schema}.${lookup_name}_lookup;" ');
INSERT INTO loader_lookuptables(process_order, lookup_name, table_name, load, level_county, level_state, level_nation, single_geom_mode, insert_mode, pre_load_process, post_load_process )
VALUES(1, 'state_all', 'state', true, false, false,true,false, 'c',
'${psql} -c "CREATE TABLE ${data_schema}.${lookup_name}(CONSTRAINT pk_${lookup_name} PRIMARY KEY (statefp),CONSTRAINT uidx_${lookup_name}_stusps UNIQUE (stusps), CONSTRAINT uidx_${lookup_name}_gid UNIQUE (gid) ) INHERITS(tiger.state); "',
@@ -312,7 +312,7 @@
'${psql} -c "ALTER TABLE ${staging_schema}.${state_abbrev}_${table_name} RENAME geoid TO cosbidfp;SELECT loader_load_staged_data(lower(''${state_abbrev}_${table_name}''), lower(''${state_abbrev}_${lookup_name}'')); ALTER TABLE ${data_schema}.${state_abbrev}_${lookup_name} ADD CONSTRAINT chk_statefp CHECK (statefp = ''${state_fips}'');"
${psql} -c "CREATE INDEX idx_${data_schema}_${state_abbrev}_${lookup_name}_countyfp ON ${data_schema}.${state_abbrev}_${lookup_name} USING btree(countyfp);"');
/** INSERT INTO loader_lookuptables(process_order, lookup_name, table_name, load, level_county, level_state, level_nation, single_geom_mode, insert_mode, pre_load_process, post_load_process, columns_exclude, website_root_override )
-- this is a bit of a lie that its county. It's really state but works better with column routine
VALUES(4, 'zcta5', 'zcta510', false,true, false,false, false, 'a',
@@ -339,7 +339,7 @@
${psql} -c "CREATE INDEX idx_${data_schema}_${state_abbrev}_${lookup_name}_tlid_statefp ON ${data_schema}.${state_abbrev}_${table_name} USING btree (tlid,statefp);"
${psql} -c "vacuum analyze ${data_schema}.${state_abbrev}_${lookup_name};"', ARRAY['gid','statefp']);
INSERT INTO loader_lookuptables(process_order, lookup_name, table_name, load, level_county, level_state, single_geom_mode, insert_mode, pre_load_process, post_load_process )
VALUES(8, 'edges', 'edges', true, true, false,false, 'a',
'${psql} -c "CREATE TABLE ${data_schema}.${state_abbrev}_${table_name}(CONSTRAINT pk_${state_abbrev}_${table_name} PRIMARY KEY (gid)) INHERITS(tiger.${table_name});" ',
@@ -360,7 +360,7 @@
${psql} -c "INSERT INTO ${data_schema}.${state_abbrev}_zip_lookup_base(zip,state,county,city, statefp) SELECT DISTINCT e.zipl, ''${state_abbrev}'', c.name,p.name,''${state_fips}'' FROM ${data_schema}.${state_abbrev}_edges AS e INNER JOIN tiger.county As c ON (e.countyfp = c.countyfp AND e.statefp = c.statefp AND e.statefp = ''${state_fips}'') INNER JOIN ${data_schema}.${state_abbrev}_faces AS f ON (e.tfidl = f.tfid OR e.tfidr = f.tfid) INNER JOIN ${data_schema}.${state_abbrev}_place As p ON(f.statefp = p.statefp AND f.placefp = p.placefp ) WHERE e.zipl IS NOT NULL;"
${psql} -c "ALTER TABLE ${data_schema}.${state_abbrev}_zip_lookup_base ADD CONSTRAINT chk_statefp CHECK (statefp = ''${state_fips}'');"
${psql} -c "CREATE INDEX idx_${data_schema}_${state_abbrev}_zip_lookup_base_citysnd ON ${data_schema}.${state_abbrev}_zip_lookup_base USING btree(soundex(city));" ');
INSERT INTO loader_lookuptables(process_order, lookup_name, table_name, load, level_county, level_state, single_geom_mode, insert_mode, pre_load_process, post_load_process,columns_exclude )
VALUES(9, 'addr', 'addr', true, true, false,false, 'a',
'${psql} -c "CREATE TABLE ${data_schema}.${state_abbrev}_${lookup_name}(CONSTRAINT pk_${state_abbrev}_${table_name} PRIMARY KEY (gid)) INHERITS(tiger.${table_name});ALTER TABLE ${data_schema}.${state_abbrev}_${lookup_name} ALTER COLUMN statefp SET DEFAULT ''${state_fips}'';" ',
@@ -372,7 +372,7 @@
${psql} -c "INSERT INTO ${data_schema}.${state_abbrev}_zip_state(zip,stusps,statefp) SELECT DISTINCT zip, ''${state_abbrev}'', ''${state_fips}'' FROM ${data_schema}.${state_abbrev}_${lookup_name} WHERE zip is not null;"
${psql} -c "ALTER TABLE ${data_schema}.${state_abbrev}_zip_state ADD CONSTRAINT chk_statefp CHECK (statefp = ''${state_fips}'');"
${psql} -c "vacuum analyze ${data_schema}.${state_abbrev}_${lookup_name};"', ARRAY['gid','statefp','fromarmid', 'toarmid']);
VALUES(9, 'addrfeat', 'addrfeat', false, true, false,true, 'a',
@@ -397,7 +397,7 @@
array_to_string( ARRAY(SELECT loader_macro_replace('cd ' || replace(variables.staging_fold,'/', platform.path_sep) || '
' || platform.wget || ' ' || variables.website_root || '/' || upper(table_name) || '/tl_' || variables.tiger_year || '_us_' || lower(table_name) || '.zip --mirror --reject=html
-|| 'cd ' || replace(variables.staging_fold,'/', platform.path_sep) || '/' || replace(replace(variables.website_root, 'http://', ''),'ftp://','') || '/' || upper(table_name) || '
+|| 'cd ' || replace(variables.staging_fold,'/', platform.path_sep) || '/' || replace(regexp_replace(variables.website_root, 'http[s]?://', ''),'ftp://','') || '/' || upper(table_name) || '
' || replace(platform.unzip_command, '*.zip', 'tl_*' || table_name || '.zip ') || '
' || COALESCE(lu.pre_load_process || E'\n', '') || platform.loader || ' -D -' || lu.insert_mode || ' -s 4269 -g the_geom '
|| CASE WHEN lu.single_geom_mode THEN ' -S ' ELSE ' ' END::text || ' -W "latin1" tl_' || variables.tiger_year
@@ -430,9 +430,9 @@
-- State level files - if an override website is specified we use that instead of variable one
array_to_string( ARRAY(SELECT 'cd ' || replace(variables.staging_fold,'/', platform.path_sep) || '
-' || platform.wget || ' ' || COALESCE(lu.website_root_override,variables.website_root || '/' || upper(table_name) ) || '/tl_' || variables.tiger_year || '_' || s.state_fips || '_' || lower(table_name) || '.zip --mirror --reject=html
+' || platform.wget || ' ' || COALESCE(lu.website_root_override,variables.website_root || '/' || upper(lookup_name) ) || '/tl_' || variables.tiger_year || '_' || s.state_fips || '_' || lower(table_name) || '.zip --mirror --reject=html
-|| 'cd ' || replace(variables.staging_fold,'/', platform.path_sep) || '/' || replace(replace(COALESCE(lu.website_root_override,variables.website_root || '/' || upper(table_name) ), 'http://', ''),'ftp://','') || '
+|| 'cd ' || replace(variables.staging_fold,'/', platform.path_sep) || '/' || replace(regexp_replace(COALESCE(lu.website_root_override, variables.website_root || '/' || upper(lookup_name) ), 'http[s]?://', ''),'ftp://','') || '
' || replace(platform.unzip_command, '*.zip', 'tl_' || variables.tiger_year || '_' || s.state_fips || '*_' || table_name || '.zip ') || '
' ||loader_macro_replace(COALESCE(lu.pre_load_process || E'\n', '') || platform.loader || ' -D -' || lu.insert_mode || ' -s 4269 -g the_geom '
|| CASE WHEN lu.single_geom_mode THEN ' -S ' ELSE ' ' END::text || ' -W "latin1" tl_' || variables.tiger_year || '_' || s.state_fips
@@ -445,12 +445,12 @@
-- County Level files
|| E'\n' ||
-- explode county files create wget call for each county file
-array_to_string (ARRAY(SELECT platform.wget || ' --mirror ' || COALESCE(lu.website_root_override,variables.website_root || '/' || upper(table_name) ) || '/tl_' || variables.tiger_year || '_' || s.state_fips || c.countyfp || '_' || lower(table_name) || '.zip ' || E'\n' AS county_out
+array_to_string (ARRAY(SELECT platform.wget || ' --mirror ' || COALESCE(lu.website_root_override, variables.website_root || '/' || upper(lookup_name) ) || '/tl_' || variables.tiger_year || '_' || s.state_fips || c.countyfp || '_' || lower(table_name) || '.zip ' || E'\n' AS county_out
FROM tiger.county As c
WHERE c.statefp = s.state_fips), ' ')
-|| 'cd ' || replace(variables.staging_fold,'/', platform.path_sep) || '/' || replace(replace(COALESCE(lu.website_root_override,variables.website_root || '/' || upper(table_name) || '/'), 'http://', ''),'ftp://','') || '
+|| 'cd ' || replace(variables.staging_fold,'/', platform.path_sep) || '/' || replace(regexp_replace(COALESCE(lu.website_root_override,variables.website_root || '/' || upper(lookup_name) || '/'), 'http[s]?://', ''),'ftp://','') || '
' || replace(platform.unzip_command, '*.zip', 'tl_*_' || s.state_fips || '*_' || table_name || '*.zip ') || '
' || loader_macro_replace(COALESCE(lu.pre_load_process || E'\n', '') || COALESCE(county_process_command || E'\n','')
|| COALESCE(E'\n' ||lu.post_load_process , '') , ARRAY['loader','table_name','lookup_name'], ARRAY[platform.loader || ' -D ' || CASE WHEN lu.single_geom_mode THEN ' -S' ELSE ' ' END::text, lu.table_name, lu.lookup_name ])
@@ -534,30 +534,32 @@
-' || platform.wget || ' ' || COALESCE(lu.website_root_override,variables.website_root || '/' || upper(table_name) ) || '/*_' || s.state_fips || '* --no-parent --relative --recursive --level=2 --accept=zip --mirror --reject=html
-' || replace(platform.unzip_command, '*.zip', 'tl_*_' || s.state_fips || '*_' || table_name || '.zip ') || '
-' ||loader_macro_replace(COALESCE(lu.pre_load_process || E'\n', '') || platform.loader || ' -' || lu.insert_mode || ' -s 4269 -g the_geom '
+|| 'cd ' || replace(variables.staging_fold,'/', platform.path_sep) || '/' || replace(regexp_replace(COALESCE(lu.website_root_override,variables.website_root || '/' || upper(lookup_name) ), 'http[s]+://', ''),'ftp://','') || '
+' || replace(platform.unzip_command, '*.zip', 'tl_' || variables.tiger_year || '_' || s.state_fips || '*_' || table_name || '.zip ') || '
+' ||loader_macro_replace(COALESCE(lu.pre_load_process || E'\n', '') || platform.loader || ' -D -' || lu.insert_mode || ' -s 4269 -g the_geom '
|| '_' || lu.table_name || '.dbf tiger_staging.' || lower(s.state_abbrev) || '_' || lu.table_name || ' | '::text || platform.psql
|| COALESCE(E'\n' ||
lu.post_load_process , '') , ARRAY['loader','table_name', 'lookup_name'], ARRAY[platform.loader, lu.table_name, lu.lookup_name ])
FROM loader_lookuptables AS lu
- WHERE level_state = true AND load = true AND lookup_name IN('tract','bg','tabblock')
+ WHERE level_state = true AND lu.lookup_name IN('bg','tract', 'tabblock')
ORDER BY process_order, lookup_name), E'\n') ::text
|| E'\n' ||
-' || array_to_string(ARRAY(SELECT platform.wget || ' --no-clobber ' || COALESCE(lu.website_root_override,variables.website_root || '/' || upper(table_name) ) || '/tl_' || variables.tiger_year || '_' || s.state_fips || c.countyfp AS out
- FROM tiger.county AS c), '
+-- explode county files create wget call for each county file
+array_to_string (ARRAY(SELECT platform.wget || ' --mirror ' || COALESCE(lu.website_root_override,variables.website_root || '/' || upper(lookup_name) ) || '/tl_' || variables.tiger_year || '_' || s.state_fips || c.countyfp || '_' || lower(table_name) || '.zip ' || E'\n' AS county_out
+FROM tiger.county As c
+WHERE c.statefp = s.state_fips), ' ')
+|| 'cd ' || replace(variables.staging_fold,'/', platform.path_sep) || '/' || replace(regexp_replace(COALESCE(lu.website_root_override,variables.website_root || '/' || upper(lookup_name) || '/'), 'http[s]+://', ''),'ftp://','') || '
- || COALESCE(E'\n' ||lu.post_load_process , '') , ARRAY['loader','table_name','lookup_name'], ARRAY[platform.loader || CASE WHEN lu.single_geom_mode THEN ' -S' ELSE ' ' END::text, lu.table_name, lu.lookup_name ])
+ || COALESCE(E'\n' ||lu.post_load_process , '') , ARRAY['loader','table_name','lookup_name'], ARRAY[platform.loader || ' -D ' || CASE WHEN lu.single_geom_mode THEN ' -S' ELSE ' ' END::text, lu.table_name, lu.lookup_name ])
- WHERE level_county = true AND load = true AND lookup_name IN('tract','bg','tabblock')
+ WHERE level_county = true AND lu.lookup_name IN('bg','tract', 'tabblock')
, ARRAY['psql', 'data_schema','staging_schema', 'staging_fold', 'state_fold', 'website_root', 'state_abbrev','state_fips'],
ARRAY[platform.psql, variables.data_schema, variables.staging_schema, variables.staging_fold, s.state_fold,variables.website_root, s.state_abbrev, s.state_fips::text])
@@ -574,4 +576,4 @@
LANGUAGE sql VOLATILE;
SELECT create_census_base_tables();
-COMMIT;
\ No newline at end of file
+COMMIT;
