[postgis-tickets] r15582 - Remove hard-coded object last update info
Sandro Santilli
strk at kbt.io
Thu Aug 24 01:58:58 PDT 2017
Author: strk
Date: 2017-08-24 01:58:58 -0700 (Thu, 24 Aug 2017)
New Revision: 15582
trunk/utils/postgis_proc_upgrade.pl
Make lack of last update info in sql file a fatal error.
Makes the script more generic (could probably be reused by
any extension)
Modified: trunk/utils/postgis_proc_upgrade.pl
--- trunk/utils/postgis_proc_upgrade.pl 2017-08-24 08:45:03 UTC (rev 15581)
+++ trunk/utils/postgis_proc_upgrade.pl 2017-08-24 08:58:58 UTC (rev 15582)
@@ -34,70 +34,11 @@
use warnings;
-# Conditionally upgraded types and operators. Only include these
-# if the major numbers in version_from are less than the version_to
-# number.
+# Conditionally upgraded types and operators based
+# on their last updated version and the version of
+# the target database
-# TODO: move configuration outside of code
-my $objs = {
- "102" => {
- "aggregates" => {
- "st_extent(geometry)" => 1,
- "st_memcollect(geometry)" => 1,
- "st_memunion(geometry)" => 1,
- "st_accum(geometry)" => 1,
- "st_union(geometry)" => 1,
- "st_collect(geometry)" => 1,
- "st_polygonize(geometry)" => 1,
- "st_makeline(geometry)" => 1
- "105" => {
- "views" => {
- "geography_columns" => 1
- "200" => {
- "aggregates" => {
- "st_3dextent(geometry)" => 1,
- "topology.topoelementarray_agg(topology.topoelement)" => 1
- "201" => {
- "aggregates" => {
- "st_samealignment(raster)" => 1,
- "st_union(raster,unionarg[])" => 1,
- "st_union(raster,integer,text)" => 1,
- "st_union(raster,integer)" => 1,
- "st_union(raster)" => 1,
- "st_union(raster,text)" => 1
- "202" => {
- "aggregates" => {
- "st_summarystatsagg(raster,integer,boolean,double precision)" => 1,
- "st_summarystatsagg(raster,boolean,double precision)" => 1,
- "st_summarystatsagg(raster,integer)" => 1,
- "st_countagg(raster,integer,boolean,double precision)" => 1,
- "st_countagg(raster,integer,boolean)" => 1,
- "st_countagg(raster,boolean)" => 1
-sub find_last_updated
- my $type = shift;
- my $sig = shift;
- for my $ver ( sort { $b cmp $a } keys %$objs ) {
- if ( $objs->{$ver}->{$type}->{$sig} ) {
- return $ver;
- return 0;
sub parse_last_updated
my $comment = shift;
@@ -245,8 +186,7 @@
my $last_updated = parse_last_updated($comment);
if ( ! $last_updated ) {
- print STDERR "WARNING: no last updated info for type '${newtype}'\n";
- $last_updated = find_last_updated("types", $newtype);
+ die "ERROR: no last updated info for type '${newtype}'\n";
my $missing = parse_missing($comment);
print "-- Type ${newtype} -- LastUpdated: ${last_updated}\n";
@@ -316,8 +256,7 @@
#print "-- Checking comment $comment\n";
- print STDERR "WARNING: no last updated info for aggregate '${aggsig}'\n";
- $last_updated = find_last_updated("aggregates", $aggsig);
+ die "ERROR: no last updated info for aggregate '${aggsig}'\n";
print "-- Aggregate ${aggsig} -- LastUpdated: ${last_updated}\n";
print <<"EOF";
@@ -352,8 +291,7 @@
- print STDERR "WARNING: no last updated info for operator '${opsig}'\n";
- $last_updated = find_last_updated("operators", $opsig);
+ die "WARNING: no last updated info for operator '${opsig}'\n";
print "-- Operator ${opsig} -- LastUpdated: ${last_updated}\n";
print <<"EOF";
@@ -416,8 +354,7 @@
- print STDERR "WARNING: no last updated info for operator family '${opfname}'\n";
- $last_updated = find_last_updated("opfamilies", $opfsig);
+ die "WARNING: no last updated info for operator family '${opfname}'\n";
print "-- Operator family ${opfsig} -- LastUpdated: ${last_updated}\n";
print <<"EOF";
@@ -482,8 +419,7 @@
- print STDERR "WARNING: no last updated info for operator class '${opclassname}'\n";
- $last_updated = find_last_updated("opclasses", $opclassname);
+ die "WARNING: no last updated info for operator class '${opclassname}'\n";
print "-- Operator class ${opclassname} -- LastUpdated: ${last_updated}\n";
print <<"EOF";
