[postgis-tickets] r15585 - fix issues with loading tabblock, incorporate changes from Jeffrey Wescott
Regina Obe lr at pcorp.us
Thu Aug 24 11:05:47 PDT 2017
Author: robe
Date: 2017-08-24 11:05:47 -0700 (Thu, 24 Aug 2017)
New Revision: 15585
   branches/2.3/NEWS
   branches/2.3/doc/installation.xml
   branches/2.3/extras/tiger_geocoder/tiger_loader_2016.sql
change url to new census ssl one
update docs to describe how to load bg, tract, tabblock tables
Closes #3698 for PostGIS 2.3.4
Closes #3816 for PostGIS 2.3.4
Modified: branches/2.3/NEWS
--- branches/2.3/NEWS	2017-08-24 16:53:15 UTC (rev 15584)
+++ branches/2.3/NEWS	2017-08-24 18:05:47 UTC (rev 15585)
@@ -12,6 +12,7 @@
   - #3800, shp2pgql-gui allow export of foreign tables, materialized views,
            and partitioned tables
   - #3806, Reverse geocoder missing suffix direction when present
+  - #3698, loading census tabblock is broken
 PostGIS 2.3.3
Modified: branches/2.3/doc/installation.xml
--- branches/2.3/doc/installation.xml	2017-08-24 16:53:15 UTC (rev 15584)
+++ branches/2.3/doc/installation.xml	2017-08-24 18:05:47 UTC (rev 15585)
@@ -1528,8 +1528,10 @@
   <sect1 id="loading_extras_tiger_geocoder">
 	<title>Installing, Upgrading Tiger Geocoder and loading data</title>
-	<para>Extras like Tiger geocoder may not be packaged in your PostGIS distribution, but will always be available in the postgis-&last_release_version;.tar.gz file. The instructions provided here are also available in the <filename>extras/tiger_geocoder/README</filename> </para>
-	<para>If you are on Windows and you don't have tar installed, you can use <ulink url="http://www.7-zip.org/">http://www.7-zip.org/</ulink> to unzip the PostGIS tarball.</para>
+	<para>Extras like Tiger geocoder may not be packaged in your PostGIS distribution. If you are missing the tiger geocoder extension or want a newer version than what your install comes with, then use
+	the <filename>share/extension/postgis_tiger_geocoder.*</filename> files from the packages in <ulink url="http://postgis.net/windows_downloads/">Windows Unreleased Versions</ulink> section for your version of PostgreSQL.
+	Although these packages are for windows, the postgis_tiger_geocoder extension files will work on any OS since the extension is an SQL/plpgsql only extension.</para>
 	<sect2 id="install_tiger_geocoder_extension">
 		<title>Tiger Geocoder Enabling your PostGIS database: Using Extension</title>
 		<para>If you are using PostgreSQL 9.1+ and PostGIS 2.1+, you can take advantage of the new extension model for installing tiger geocoder. To do so:</para>
@@ -1571,14 +1573,41 @@
 where the tiger files will be downloaded to and processed.  If you are not happy with having the folder on the root of the server, or simply want to change to a different folder for staging, then edit the field <varname>staging_fold</varname> in the <varname>tiger.loader_variables</varname> table.</para></listitem>
             <listitem><para>Create a folder called temp in the <filename>gisdata</filename> folder or whereever you designated the <varname>staging_fold</varname> to be.  This will be
 the folder where the loader extracts the downloaded tiger data.</para></listitem>
-			<listitem><para>Then run the  <xref linkend="Loader_Generate_Nation_Script" /> and <xref linkend="Loader_Generate_Script" />  SQL functions make sure to use the name of your custom profile and copy the scripts to a .sh or .bat file.  So for example to do the nation load and one state using our new profile, you can do this using psql:</para>
+			<listitem><para>Then run the  <xref linkend="Loader_Generate_Nation_Script" />  SQL function make sure to use the name of your custom profile and copy the script to a .sh or .bat file.  So for example to build  the nation load:</para>
 					<programlisting>psql -c "SELECT Loader_Generate_Nation_Script('debbie')" -d geocoder -tA > /gisdata/nation_script_load.sh</programlisting>
-					<programlisting>psql -c "SELECT Loader_Generate_Script(ARRAY['MA'], 'debbie')" -d geocoder -tA > /gisdata/ma_load.sh</programlisting>
 			</listitem>
+			<listitem><para>Run the generated nation load commandline scripts.</para>
+				<programlisting>cd /gisdata
+sh nation_script_load.sh</programlisting>
+      </listitem>
+      <listitem><para>After you are done running the nation script, you should have three tables in your <code>tiger_data</code> schema and they should be filled with data. Confirm you do by doing the following queries from psql or pgAdmin</para>
+				<programlisting>SELECT count(*) FROM tiger_data.county_all;</programlisting>
+<screen> count
+  3233
+(1 row)</screen>
+				<programlisting>SELECT count(*) FROM tiger_data.state_all;</programlisting>
+<screen>
+ count
+    56
+(1 row)
+</screen>
+      </listitem>
+			<listitem><para>By default the tables corresponding to <varname>bg</varname>, <varname>tract</varname>, <varname>tabblock</varname> are not loaded. These tables are not used by the geocoder but are used by folks for population statistics.
+			 If you wish to load them as part of your state loads, run the following statement to enable them.</para>
+				<programlisting>UPDATE tiger.loader_lookuptables SET load = true WHERE load = false AND lookup_name IN('tract', 'bg', 'tabblock');</programlisting>
+				<para>Alternatively you can load just these tables after loading state data using the <xref linkend="Loader_Generate_Census_Script" /></para></listitem>
+			<listitem><para>For each state you want to load data for, generate a state script <xref linkend="Loader_Generate_Script" />.</para><warning><para>DO NOT Generate the state script until you have already loaded the nation data, because the state script utilizes county list loaded by nation script.</para></warning></listitem>
+			<listitem><programlisting>psql -c "SELECT Loader_Generate_Script(ARRAY['MA'], 'debbie')" -d geocoder -tA > /gisdata/ma_load.sh</programlisting></listitem>
 			<listitem><para>Run the generated commandline scripts.</para>
-sh nation_script_load.sh
 sh ma_load.sh</programlisting>
 			</listitem>
 			<listitem><para>After you are done loading all data or at a stopping point, it's a good idea to analyze all the tiger tables to update the stats (include inherited stats)</para>
Modified: branches/2.3/extras/tiger_geocoder/tiger_loader_2016.sql
--- branches/2.3/extras/tiger_geocoder/tiger_loader_2016.sql	2017-08-24 16:53:15 UTC (rev 15584)
+++ branches/2.3/extras/tiger_geocoder/tiger_loader_2016.sql	2017-08-24 18:05:47 UTC (rev 15585)
@@ -42,7 +42,7 @@
 	  CONSTRAINT enforce_geotype_geom CHECK (geometrytype(the_geom) = 'MULTIPOLYGON'::text OR the_geom IS NULL),
 	  CONSTRAINT enforce_srid_geom CHECK (st_srid(the_geom) = 4269)
 	DROP TABLE IF EXISTS tiger.tabblock;
 	CREATE TABLE tabblock
@@ -221,7 +221,7 @@
 TRUNCATE TABLE loader_variables;
 INSERT INTO loader_variables(tiger_year, website_root , staging_fold, data_schema, staging_schema)
-	VALUES('2016', 'http://www2.census.gov/geo/tiger/TIGER2016', '/gisdata', 'tiger_data', 'tiger_staging');
+	VALUES('2016', 'https://www2.census.gov/geo/tiger/TIGER2016', '/gisdata', 'tiger_data', 'tiger_staging');
 GRANT SELECT ON TABLE loader_variables TO public;
 DO $$
@@ -243,9 +243,9 @@
 TRUNCATE TABLE loader_lookuptables;
 GRANT SELECT ON TABLE loader_lookuptables TO public;
 -- put in explanatory comments of what each column is for
 COMMENT ON COLUMN loader_lookuptables.lookup_name IS 'This is the table name to inherit from and suffix of resulting output table -- how the table will be named --  edges here would mean -- ma_edges , pa_edges etc. except in the case of national tables. national level tables have no prefix';
 COMMENT ON COLUMN loader_lookuptables.level_nation IS 'These are tables that contain all data for the whole US so there is just a single file';
@@ -263,16 +263,16 @@
 	${psql} -c "ALTER TABLE ${data_schema}.${state_abbrev}_${lookup_name} ADD CONSTRAINT chk_statefp CHECK (statefp = ''${state_fips}'');"', ARRAY['gid']);
 INSERT INTO loader_lookuptables(process_order, lookup_name, table_name, load, level_county, level_state, single_geom_mode, insert_mode, pre_load_process, post_load_process, columns_exclude )
-VALUES(11, 'tabblock', 'tabblock', false, false, true,false, 'c',
+VALUES(11, 'tabblock', 'tabblock10', false, false, true,false, 'c',
 '${psql} -c "CREATE TABLE ${data_schema}.${state_abbrev}_${lookup_name}(CONSTRAINT pk_${state_abbrev}_${lookup_name} PRIMARY KEY (tabblock_id)) INHERITS(tiger.${lookup_name});" ',
-'${psql} -c "ALTER TABLE ${staging_schema}.${state_abbrev}_${lookup_name} RENAME geoid10 TO tabblock_id;"
+'${psql} -c "ALTER TABLE ${staging_schema}.${state_abbrev}_${lookup_name} RENAME geoid10 TO tabblock_id;  SELECT loader_load_staged_data(lower(''${state_abbrev}_${table_name}''), lower(''${state_abbrev}_${lookup_name}'')); "
 ${psql} -c "CREATE INDEX ${data_schema}_${state_abbrev}_${lookup_name}_the_geom_gist ON ${data_schema}.${state_abbrev}_${lookup_name} USING gist(the_geom);"
-${psql} -c "vacuum analyze ${data_schema}.${state_abbrev}_${lookup_name};"', '{gid, uatyp10, uatype, tractce10, blockce10,suffix1ce,blockce,tractce}'::text[]);
+${psql} -c "vacuum analyze ${data_schema}.${state_abbrev}_${lookup_name};"', '{gid, uatyp10, uatype, suffix1ce}'::text[]);
-VALUES(12, 'bg', 'bg', true,false, true,false, 'c',
+VALUES(12, 'bg', 'bg', false,false, true,false, 'c',
 '${psql} -c "CREATE TABLE ${data_schema}.${state_abbrev}_${lookup_name}(CONSTRAINT pk_${state_abbrev}_${lookup_name} PRIMARY KEY (bg_id)) INHERITS(tiger.${lookup_name});" ',
 '${psql} -c "ALTER TABLE ${staging_schema}.${state_abbrev}_${table_name} RENAME geoid TO bg_id;  SELECT loader_load_staged_data(lower(''${state_abbrev}_${table_name}''), lower(''${state_abbrev}_${lookup_name}'')); "
@@ -289,7 +289,7 @@
 	${psql} -c "VACUUM ANALYZE ${data_schema}.${lookup_name};"
 	${psql} -c "INSERT INTO ${data_schema}.${lookup_name}_lookup(st_code, state, co_code, name) SELECT CAST(s.statefp as integer), s.abbrev, CAST(c.countyfp as integer), c.name FROM ${data_schema}.${lookup_name} As c INNER JOIN state_lookup As s ON s.statefp = c.statefp;"
 	${psql} -c "VACUUM ANALYZE ${data_schema}.${lookup_name}_lookup;" ');
 INSERT INTO loader_lookuptables(process_order, lookup_name, table_name, load, level_county, level_state, level_nation, single_geom_mode, insert_mode, pre_load_process, post_load_process )
 VALUES(1, 'state_all', 'state', true, false, false,true,false, 'c',
 	'${psql} -c "CREATE TABLE ${data_schema}.${lookup_name}(CONSTRAINT pk_${lookup_name} PRIMARY KEY (statefp),CONSTRAINT uidx_${lookup_name}_stusps  UNIQUE (stusps), CONSTRAINT uidx_${lookup_name}_gid UNIQUE (gid) ) INHERITS(tiger.state); "',
@@ -312,7 +312,7 @@
 	'${psql} -c "ALTER TABLE ${staging_schema}.${state_abbrev}_${table_name} RENAME geoid TO cosbidfp;SELECT loader_load_staged_data(lower(''${state_abbrev}_${table_name}''), lower(''${state_abbrev}_${lookup_name}'')); ALTER TABLE ${data_schema}.${state_abbrev}_${lookup_name} ADD CONSTRAINT chk_statefp CHECK (statefp = ''${state_fips}'');"
 ${psql} -c "CREATE INDEX idx_${data_schema}_${state_abbrev}_${lookup_name}_countyfp ON ${data_schema}.${state_abbrev}_${lookup_name} USING btree(countyfp);"');
 /** INSERT INTO loader_lookuptables(process_order, lookup_name, table_name, load, level_county, level_state, level_nation, single_geom_mode, insert_mode, pre_load_process, post_load_process, columns_exclude, website_root_override  )
 -- this is a bit of a lie that its county.  It's really state but works better with column routine
 VALUES(4, 'zcta5', 'zcta510', false,true, false,false, false, 'a',
@@ -339,7 +339,7 @@
 ${psql} -c "CREATE INDEX idx_${data_schema}_${state_abbrev}_${lookup_name}_tlid_statefp ON ${data_schema}.${state_abbrev}_${table_name} USING btree (tlid,statefp);"
 ${psql} -c "vacuum analyze ${data_schema}.${state_abbrev}_${lookup_name};"', ARRAY['gid','statefp']);
 INSERT INTO loader_lookuptables(process_order, lookup_name, table_name, load, level_county, level_state, single_geom_mode, insert_mode, pre_load_process, post_load_process )
 VALUES(8, 'edges', 'edges', true, true, false,false, 'a',
 '${psql} -c "CREATE TABLE ${data_schema}.${state_abbrev}_${table_name}(CONSTRAINT pk_${state_abbrev}_${table_name} PRIMARY KEY (gid)) INHERITS(tiger.${table_name});" ',
@@ -360,7 +360,7 @@
 ${psql} -c "INSERT INTO ${data_schema}.${state_abbrev}_zip_lookup_base(zip,state,county,city, statefp) SELECT DISTINCT e.zipl, ''${state_abbrev}'', c.name,p.name,''${state_fips}''  FROM ${data_schema}.${state_abbrev}_edges AS e INNER JOIN tiger.county As c  ON (e.countyfp = c.countyfp AND e.statefp = c.statefp AND e.statefp = ''${state_fips}'') INNER JOIN ${data_schema}.${state_abbrev}_faces AS f ON (e.tfidl = f.tfid OR e.tfidr = f.tfid) INNER JOIN ${data_schema}.${state_abbrev}_place As p ON(f.statefp = p.statefp AND f.placefp = p.placefp ) WHERE e.zipl IS NOT NULL;"
 ${psql} -c "ALTER TABLE ${data_schema}.${state_abbrev}_zip_lookup_base ADD CONSTRAINT chk_statefp CHECK (statefp = ''${state_fips}'');"
 ${psql} -c "CREATE INDEX idx_${data_schema}_${state_abbrev}_zip_lookup_base_citysnd ON ${data_schema}.${state_abbrev}_zip_lookup_base USING btree(soundex(city));" ');
 INSERT INTO loader_lookuptables(process_order, lookup_name, table_name, load, level_county, level_state, single_geom_mode, insert_mode, pre_load_process, post_load_process,columns_exclude )
 VALUES(9, 'addr', 'addr', true, true, false,false, 'a',
 	'${psql} -c "CREATE TABLE ${data_schema}.${state_abbrev}_${lookup_name}(CONSTRAINT pk_${state_abbrev}_${table_name} PRIMARY KEY (gid)) INHERITS(tiger.${table_name});ALTER TABLE ${data_schema}.${state_abbrev}_${lookup_name} ALTER COLUMN statefp SET DEFAULT ''${state_fips}'';" ',
@@ -372,7 +372,7 @@
 	${psql} -c "INSERT INTO ${data_schema}.${state_abbrev}_zip_state(zip,stusps,statefp) SELECT DISTINCT zip, ''${state_abbrev}'', ''${state_fips}'' FROM ${data_schema}.${state_abbrev}_${lookup_name} WHERE zip is not null;"
 	${psql} -c "ALTER TABLE ${data_schema}.${state_abbrev}_zip_state ADD CONSTRAINT chk_statefp CHECK (statefp = ''${state_fips}'');"
 	${psql} -c "vacuum analyze ${data_schema}.${state_abbrev}_${lookup_name};"',  ARRAY['gid','statefp','fromarmid', 'toarmid']);
 VALUES(9, 'addrfeat', 'addrfeat', false, true, false,true, 'a',
@@ -397,7 +397,7 @@
 	array_to_string( ARRAY(SELECT loader_macro_replace('cd ' || replace(variables.staging_fold,'/', platform.path_sep) || '
 ' || platform.wget || ' ' || variables.website_root  || '/' || upper(table_name)  || '/tl_' || variables.tiger_year || '_us_' || lower(table_name) || '.zip --mirror --reject=html
-|| 'cd ' ||  replace(variables.staging_fold,'/', platform.path_sep) || '/' || replace(replace(variables.website_root, 'http://', ''),'ftp://','')  || '/' || upper(table_name)  || '
+|| 'cd ' ||  replace(variables.staging_fold,'/', platform.path_sep) || '/' || replace(regexp_replace(variables.website_root, 'http[s]?://', ''),'ftp://','')  || '/' || upper(table_name)  || '
 ' || replace(platform.unzip_command, '*.zip', 'tl_*' || table_name || '.zip ') || '
 ' || COALESCE(lu.pre_load_process || E'\n', '') || platform.loader || ' -D -' ||  lu.insert_mode || ' -s 4269 -g the_geom '
 		|| CASE WHEN lu.single_geom_mode THEN ' -S ' ELSE ' ' END::text || ' -W "latin1" tl_' || variables.tiger_year
@@ -430,9 +430,9 @@
 	-- State level files - if an override website is specified we use that instead of variable one
 	array_to_string( ARRAY(SELECT 'cd ' || replace(variables.staging_fold,'/', platform.path_sep) || '
-' || platform.wget || ' ' || COALESCE(lu.website_root_override,variables.website_root || '/' || upper(table_name)  ) || '/tl_' || variables.tiger_year || '_' || s.state_fips || '_' || lower(table_name) || '.zip --mirror --reject=html
+' || platform.wget || ' ' || COALESCE(lu.website_root_override,variables.website_root || '/' || upper(lookup_name)  ) || '/tl_' || variables.tiger_year || '_' || s.state_fips || '_' || lower(table_name) || '.zip --mirror --reject=html
-|| 'cd ' ||  replace(variables.staging_fold,'/', platform.path_sep) || '/' || replace(replace(COALESCE(lu.website_root_override,variables.website_root || '/' || upper(table_name) ), 'http://', ''),'ftp://','')    || '
+|| 'cd ' ||  replace(variables.staging_fold,'/', platform.path_sep) || '/' || replace(regexp_replace(COALESCE(lu.website_root_override, variables.website_root || '/' || upper(lookup_name) ), 'http[s]?://', ''),'ftp://','')    || '
 ' || replace(platform.unzip_command, '*.zip', 'tl_' || variables.tiger_year || '_' || s.state_fips || '*_' || table_name || '.zip ') || '
 ' ||loader_macro_replace(COALESCE(lu.pre_load_process || E'\n', '') || platform.loader || ' -D -' ||  lu.insert_mode || ' -s 4269 -g the_geom '
 		|| CASE WHEN lu.single_geom_mode THEN ' -S ' ELSE ' ' END::text || ' -W "latin1" tl_' || variables.tiger_year || '_' || s.state_fips
@@ -445,12 +445,12 @@
 	-- County Level files
 	|| E'\n' ||
 -- explode county files create wget call for each county file
-array_to_string (ARRAY(SELECT platform.wget || ' --mirror  ' || COALESCE(lu.website_root_override,variables.website_root || '/' || upper(table_name)  ) || '/tl_' || variables.tiger_year || '_' || s.state_fips || c.countyfp || '_' || lower(table_name) || '.zip ' || E'\n'  AS county_out
+array_to_string (ARRAY(SELECT platform.wget || ' --mirror  ' || COALESCE(lu.website_root_override, variables.website_root || '/' || upper(lookup_name)  ) || '/tl_' || variables.tiger_year || '_' || s.state_fips || c.countyfp || '_' || lower(table_name) || '.zip ' || E'\n'  AS county_out
 FROM tiger.county As c
 WHERE c.statefp = s.state_fips), ' ')
-|| 'cd ' ||  replace(variables.staging_fold,'/', platform.path_sep) || '/' || replace(replace(COALESCE(lu.website_root_override,variables.website_root || '/' || upper(table_name)  || '/'), 'http://', ''),'ftp://','')  || '
+|| 'cd ' ||  replace(variables.staging_fold,'/', platform.path_sep) || '/' || replace(regexp_replace(COALESCE(lu.website_root_override,variables.website_root || '/' || upper(lookup_name)  || '/'), 'http[s]?://', ''),'ftp://','')  || '
 ' || replace(platform.unzip_command, '*.zip', 'tl_*_' || s.state_fips || '*_' || table_name || '*.zip ') || '
 ' || loader_macro_replace(COALESCE(lu.pre_load_process || E'\n', '') || COALESCE(county_process_command || E'\n','')
 				|| COALESCE(E'\n' ||lu.post_load_process , '') , ARRAY['loader','table_name','lookup_name'], ARRAY[platform.loader  || ' -D ' || CASE WHEN lu.single_geom_mode THEN ' -S' ELSE ' ' END::text, lu.table_name, lu.lookup_name ])
@@ -534,30 +534,32 @@
-' || platform.wget || ' ' || COALESCE(lu.website_root_override,variables.website_root || '/' || upper(table_name)  ) || '/*_' || s.state_fips || '* --no-parent --relative --recursive --level=2 --accept=zip --mirror --reject=html
-' || replace(platform.unzip_command, '*.zip', 'tl_*_' || s.state_fips || '*_' || table_name || '.zip ') || '
-' ||loader_macro_replace(COALESCE(lu.pre_load_process || E'\n', '') || platform.loader || ' -' ||  lu.insert_mode || ' -s 4269 -g the_geom '
+|| 'cd ' ||  replace(variables.staging_fold,'/', platform.path_sep) || '/' || replace(regexp_replace(COALESCE(lu.website_root_override,variables.website_root || '/' || upper(lookup_name) ), 'http[s]+://', ''),'ftp://','')    || '
+' || replace(platform.unzip_command, '*.zip', 'tl_' || variables.tiger_year || '_' || s.state_fips || '*_' || table_name || '.zip ') || '
+' ||loader_macro_replace(COALESCE(lu.pre_load_process || E'\n', '') || platform.loader || ' -D -' ||  lu.insert_mode || ' -s 4269 -g the_geom '
 	|| '_' || lu.table_name || '.dbf tiger_staging.' || lower(s.state_abbrev) || '_' || lu.table_name || ' | '::text || platform.psql
 		|| COALESCE(E'\n' ||
 			lu.post_load_process , '') , ARRAY['loader','table_name', 'lookup_name'], ARRAY[platform.loader, lu.table_name, lu.lookup_name ])
 				FROM loader_lookuptables AS lu
-				WHERE level_state = true AND load = true AND lookup_name IN('tract','bg','tabblock')
+				WHERE level_state = true AND lu.lookup_name IN('bg','tract', 'tabblock')
 				ORDER BY process_order, lookup_name), E'\n') ::text
 	|| E'\n' ||
-' || array_to_string(ARRAY(SELECT platform.wget || ' --no-clobber ' || COALESCE(lu.website_root_override,variables.website_root || '/' || upper(table_name)  ) || '/tl_' || variables.tiger_year || '_' || s.state_fips || c.countyfp AS out
- FROM tiger.county AS c), '
+-- explode county files create wget call for each county file
+array_to_string (ARRAY(SELECT platform.wget || ' --mirror  ' || COALESCE(lu.website_root_override,variables.website_root || '/' || upper(lookup_name)  ) || '/tl_' || variables.tiger_year || '_' || s.state_fips || c.countyfp || '_' || lower(table_name) || '.zip ' || E'\n'  AS county_out
+FROM tiger.county As c
+WHERE c.statefp = s.state_fips), ' ')
+|| 'cd ' ||  replace(variables.staging_fold,'/', platform.path_sep) || '/' || replace(regexp_replace(COALESCE(lu.website_root_override,variables.website_root || '/' || upper(lookup_name)  || '/'), 'http[s]+://', ''),'ftp://','')  || '
-				|| COALESCE(E'\n' ||lu.post_load_process , '') , ARRAY['loader','table_name','lookup_name'], ARRAY[platform.loader  || CASE WHEN lu.single_geom_mode THEN ' -S' ELSE ' ' END::text, lu.table_name, lu.lookup_name ])
+				|| COALESCE(E'\n' ||lu.post_load_process , '') , ARRAY['loader','table_name','lookup_name'], ARRAY[platform.loader  || ' -D ' || CASE WHEN lu.single_geom_mode THEN ' -S' ELSE ' ' END::text, lu.table_name, lu.lookup_name ])
-				WHERE level_county = true AND load = true AND lookup_name IN('tract','bg','tabblock')
+				WHERE level_county = true AND lu.lookup_name IN('bg','tract', 'tabblock')
 	, ARRAY['psql', 'data_schema','staging_schema', 'staging_fold', 'state_fold', 'website_root', 'state_abbrev','state_fips'],
 	ARRAY[platform.psql,  variables.data_schema, variables.staging_schema, variables.staging_fold, s.state_fold,variables.website_root, s.state_abbrev, s.state_fips::text])
@@ -574,4 +576,4 @@
   LANGUAGE sql VOLATILE;
 SELECT create_census_base_tables();
-COMMIT;
\ No newline at end of file
+COMMIT;
