[postgis-tickets] [PostGIS] #3723: st_geohash not correct for some multipoint
trac at osgeo.org
Sun Aug 27 08:39:55 PDT 2017
Reporter: hzhang | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.4.0
Component: postgis | Version: 2.2.x
Resolution: | Keywords: st_geohash
Comment (by robe):
I think the issue here has to do with how ST_GeoHash computes it's default
precision. In the examples you demonstrated, it decided the best precision
is 0 which always returns nothing.
So for example:
SELECT ST_GeoHash(ST_GeomFromText('LINESTRING (1 1, 40 40)') ,2 );
yields:
s7
Which is probably closer to what you are expecting but then that is wrong
too since it doesn't cover the linestring so it needs a lower precision
than that. 1, would give you the right answer.
Same case here:
SELECT st_geohash(st_geomfromtext('multipoint(166.2 60.2, 175.6
67.5)'),1);
yields:
z
I wonder if it would be safe to change the precision to 1 in cases where
it decides precision should be 0.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3723#comment:3>
