[postgis-tickets] r15598 - Allow signed distance for ST_Project (Darafei Praliaskouski)
Regina Obe
lr at pcorp.us
Sun Aug 27 08:17:40 PDT 2017
Author: robe
Date: 2017-08-27 08:17:39 -0700 (Sun, 27 Aug 2017)
New Revision: 15598
trunk/NEWS
trunk/doc/reference_measure.xml
trunk/liblwgeom/lwgeodetic.c
trunk/regress/tickets.sql
trunk/regress/tickets_expected
Closes https://github.com/postgis/postgis/pull/138
Closes #3709
Modified: trunk/NEWS
--- trunk/NEWS 2017-08-27 07:02:10 UTC (rev 15597)
+++ trunk/NEWS 2017-08-27 15:17:39 UTC (rev 15598)
@@ -18,6 +18,7 @@
- Most aggregates (raster and geometry),
and all stable / immutable (raster and geometry) marked as parallel safe
- #2249, ST_MakeEmptyCoverage for raster (David Zwarg, ainomieli)
+ - #3709, Allow signed distance for ST_Project (Darafei Praliaskouski)
* Enhancements *
Modified: trunk/doc/reference_measure.xml
--- trunk/doc/reference_measure.xml 2017-08-27 07:02:10 UTC (rev 15597)
+++ trunk/doc/reference_measure.xml 2017-08-27 15:17:39 UTC (rev 15598)
@@ -4344,6 +4344,7 @@
<para>The distance is given in meters.</para>
<para>Availability: 2.0.0</para>
+ <para>Enhanced: 2.4.0 Allow negative distance and non-normalized azimuth.</para>
</refsection>
Modified: trunk/liblwgeom/lwgeodetic.c
--- trunk/liblwgeom/lwgeodetic.c 2017-08-27 07:02:10 UTC (rev 15597)
+++ trunk/liblwgeom/lwgeodetic.c 2017-08-27 15:17:39 UTC (rev 15598)
@@ -2009,18 +2009,20 @@
double x, y;
POINTARRAY *pa;
LWPOINT *lwp;
- /* Check the azimuth validity, convert to radians */
- if ( azimuth < -2.0 * M_PI || azimuth > 2.0 * M_PI )
- lwerror("Azimuth must be between -2PI and 2PI");
- return NULL;
+ /* Normalize distance to be positive*/
+ if ( distance < 0.0 ) {
+ distance = -distance;
+ azimuth += M_PI;
+ /* Normalize azimuth */
+ azimuth -= 2.0 * M_PI * floor(azimuth / (2.0 * M_PI));
/* Check the distance validity */
- if ( distance < 0.0 || distance > (M_PI * spheroid->radius) )
+ if ( distance > (M_PI * spheroid->radius) )
- lwerror("Distance must be between 0 and %g", M_PI * spheroid->radius);
+ lwerror("Distance must not be greater than %g", M_PI * spheroid->radius);
return NULL;
Modified: trunk/regress/tickets.sql
--- trunk/regress/tickets.sql 2017-08-27 07:02:10 UTC (rev 15597)
+++ trunk/regress/tickets.sql 2017-08-27 15:17:39 UTC (rev 15598)
@@ -1015,5 +1015,8 @@
-- #3704
SELECT '#3704', ST_AsX3D('LINESTRING EMPTY') = '';
+-- #3709
+select '#3709', ST_SnapToGrid(ST_Project('SRID=4326;POINT(1 1)'::geography, 100000, 20)::geometry, 0.0001) = ST_SnapToGrid(ST_Project('SRID=4326;POINT(1 1)'::geography, -100000, 20+pi())::geometry, 0.0001);
-- Clean up
DELETE FROM spatial_ref_sys;
Modified: trunk/regress/tickets_expected
--- trunk/regress/tickets_expected 2017-08-27 07:02:10 UTC (rev 15597)
+++ trunk/regress/tickets_expected 2017-08-27 15:17:39 UTC (rev 15598)
@@ -302,3 +302,4 @@
#3627a|o}~~|AdshNoSsBgd at eGoBlm@wKhj@~@?
#3627b|t
#3704|t
+#3709|t
