[postgis-tickets] r15605 - ST_AsMVTGeom move normalize to test logic
bjorn at wololo.org
bjorn at wololo.org
Tue Aug 29 09:58:29 PDT 2017
Author: bjornharrtell
Date: 2017-08-29 09:58:29 -0700 (Tue, 29 Aug 2017)
New Revision: 15605
trunk/postgis/mvt.c
trunk/regress/mvt.sql
Closes #3819
Modified: trunk/postgis/mvt.c
--- trunk/postgis/mvt.c 2017-08-29 07:27:53 UTC (rev 15604)
+++ trunk/postgis/mvt.c 2017-08-29 16:58:29 UTC (rev 15605)
@@ -721,7 +721,7 @@
if (lwgeom_out == NULL || lwgeom_is_empty(lwgeom_out))
return NULL;
- return lwgeom_normalize(lwgeom_out);
+ return lwgeom_out;
Modified: trunk/regress/mvt.sql
--- trunk/regress/mvt.sql 2017-08-29 07:27:53 UTC (rev 15604)
+++ trunk/regress/mvt.sql 2017-08-29 16:58:29 UTC (rev 15605)
@@ -1,114 +1,114 @@
-- geometry preprocessing tests
-select 'PG1', ST_AsText(ST_AsMVTGeom(
+select 'PG1', ST_AsText(ST_Normalize(ST_AsMVTGeom(
ST_Point(1, 2),
ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)),
- 4096, 0, false));
-select 'PG2', ST_AsText(ST_AsMVTGeom(
+ 4096, 0, false)));
+select 'PG2', ST_AsText(ST_Normalize(ST_AsMVTGeom(
ST_Point(1, 2),
ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096*2, 4096*2)),
- 4096, 0, false));
-select 'PG3', ST_AsText(ST_AsMVTGeom(
+select 'PG3', ST_AsText(ST_Normalize(ST_AsMVTGeom(
ST_Point(1, 2),
ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096/2, 4096/2)),
- 4096, 0, false));
-select 'PG4', ST_AsText(ST_AsMVTGeom(
+select 'PG4', ST_AsText(ST_Normalize(ST_AsMVTGeom(
ST_GeomFromText('POLYGON ((0 0, 10 0, 10 5, 0 -5, 0 0))'),
- 4096, 0, false));
-select 'PG5', ST_AsText(ST_AsMVTGeom(
+select 'PG5', ST_AsText(ST_Normalize(ST_AsMVTGeom(
ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096*4096, 4096*4096)),
- 4096, 0, false));
-select 'PG6', ST_AsText(ST_AsMVTGeom(
+select 'PG6', ST_AsText(ST_Normalize(ST_AsMVTGeom(
ST_GeomFromText('POLYGON ((762780 6474467, 717821 6797045, 1052826 6797045, 762780 6474467))'),
ST_MakeBox2D(ST_Point(626172.135625, 6261721.35625), ST_Point(1252344.27125, 6887893.49188)),
- 4096, 0, false));
-select 'PG7', ST_AsText(ST_AsMVTGeom(
+select 'PG7', ST_AsText(ST_Normalize(ST_AsMVTGeom(
ST_GeomFromText('POLYGON((-7792023.4539488 1411512.60791779,-7785283.40665468 1406282.69482469,-7783978.88137195 1404858.20373788,-7782986.89858399 1402324.91434802,-7779028.02672366 1397370.31802772,
-7778652.06985644 1394387.75452545,-7779906.76953697 1393279.22658385,-7782212.33678782 1393293.14086794,-7784631.14401331 1394225.4151684,-7786257.27108231 1395867.40241344,-7783978.88137195 1395867.40241344,
-7783978.88137195 1396646.68250521,-7787752.03959369 1398469.72134299,-7795443.30325373 1405280.43988858,-7797717.16326269 1406217.73286975,-7798831.44531677 1406904.48130551,-7799311.5830898 1408004.24038921,
-7799085.10302919 1409159.72782477,-7798052.35381919 1411108.84582812,-7797789.63692662 1412213.40365339,-7798224.47868753 1414069.89725829,-7799003.5701851 1415694.42577482,-7799166.63587328 1416966.26267896,
-7797789.63692662 1417736.81850415,-7793160.38395328 1412417.61222784,-7792023.4539488 1411512.60791779))'),
ST_MakeBox2D(ST_Point(-20037508.34, 20037508.34), ST_Point(20037508.34, -20037508.34)),
- 4096, 10, true));
-select 'PG8', ST_AsText(ST_AsMVTGeom(
+ 4096, 10, true)));
+select 'PG8', ST_AsText(ST_Normalize(ST_AsMVTGeom(
ST_GeomFromText('GEOMETRYCOLLECTION(MULTIPOLYGON (((0 0, 10 0, 10 5, 0 -5, 0 0))))'),
- 4096, 0, false));
-select 'PG9', ST_AsText(ST_AsMVTGeom(
+select 'PG9', ST_AsText(ST_Normalize(ST_AsMVTGeom(
ST_GeomFromText('POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0))'),
ST_MakeBox2D(ST_Point(0, 0), ST_Point(5, 5)),
- 4096, 0, true));
+ 4096, 0, true)));
-- geometry encoding tests
SELECT 'TG1', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1,
- ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
- ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0, false) AS geom) AS q;
+ ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
+ ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0, false)) AS geom) AS q;
SELECT 'TG2', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1,
- ST_AsMVTGeom(ST_GeomFromText('MULTIPOINT(25 17, 26 18)'),
+ ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('MULTIPOINT(25 17, 26 18)'),
SELECT 'TG3', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1,
- ST_AsMVTGeom(ST_GeomFromText('LINESTRING(0 0, 1000 1000)'),
+ ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('LINESTRING(0 0, 1000 1000)'),
SELECT 'TG4', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1,
- ST_AsMVTGeom(ST_GeomFromText('LINESTRING(0 0, 500 500, 1000 1000)'),
+ ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('LINESTRING(0 0, 500 500, 1000 1000)'),
SELECT 'TG5', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1,
- ST_AsMVTGeom(ST_GeomFromText('MULTILINESTRING((1 1, 501 501, 1001 1001),(2 2, 502 502, 1002 1002))'),
+ ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('MULTILINESTRING((1 1, 501 501, 1001 1001),(2 2, 502 502, 1002 1002))'),
SELECT 'TG6', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1,
- ST_AsMVTGeom(ST_GeomFromText('POLYGON ((35 10, 45 45, 15 40, 10 20, 35 10), (20 30, 35 35, 30 20, 20 30))'),
+ ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POLYGON ((35 10, 45 45, 15 40, 10 20, 35 10), (20 30, 35 35, 30 20, 20 30))'),
SELECT 'TG7', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1,
- ST_AsMVTGeom(ST_GeomFromText('MULTIPOLYGON (((40 40, 20 45, 45 30, 40 40)), ((20 35, 10 30, 10 10, 30 5, 45 20, 20 35), (30 20, 20 15, 20 25, 30 20)))'),
+ ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('MULTIPOLYGON (((40 40, 20 45, 45 30, 40 40)), ((20 35, 10 30, 10 10, 30 5, 45 20, 20 35), (30 20, 20 15, 20 25, 30 20)))'),
SELECT 'TG8', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1,
SELECT 'TG9', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1,
- ST_AsMVTGeom(ST_GeomFromText('MULTIPOINT(25 17, -26 -18)'),
+ ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('MULTIPOINT(25 17, -26 -18)'),
-- attribute encoding tests
SELECT 'TA1', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1, 'abcd'::text AS c2,
SELECT 'TA2', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1.1::double precision AS c1,
SELECT 'TA3', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT NULL::integer AS c1,
SELECT 'TA4', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (
- SELECT 1 AS c1, ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
+ SELECT 1 AS c1, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
UNION
- SELECT 2 AS c1, ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
+ SELECT 2 AS c1, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
SELECT 'TA5', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT
- ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0, false) AS geom, 1 AS c1, 'abcd'::text AS c2) AS q;
+ ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0, false)) AS geom, 1 AS c1, 'abcd'::text AS c2) AS q;
SELECT 'TA6', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (SELECT 1 AS c1, -1 AS c2,
SELECT 'TA7', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (
- SELECT 'test' AS c1, ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
+ SELECT 'test' AS c1, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
UNION
- SELECT 'test' AS c1, ST_AsMVTGeom(ST_GeomFromText('POINT(26 18)'),
+ SELECT 'test' AS c1, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(26 18)'),
UNION
- SELECT 'othertest' AS c1, ST_AsMVTGeom(ST_GeomFromText('POINT(26 18)'),
+ SELECT 'othertest' AS c1, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(26 18)'),
SELECT 'TA8', encode(ST_AsMVT('test', 4096, 'geom', q), 'base64') FROM (
- SELECT 1::int AS c1, ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
+ SELECT 1::int AS c1, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
UNION
- SELECT 1::int AS c1, ST_AsMVTGeom(ST_GeomFromText('POINT(26 18)'),
+ SELECT 1::int AS c1, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(26 18)'),
UNION
- SELECT 2::int AS c1, ST_AsMVTGeom(ST_GeomFromText('POINT(26 18)'),
+ SELECT 2::int AS c1, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(26 18)'),
-- unsupported input
SELECT 'TU2';
