[postgis-tickets] r15607 - ST_AsMVTGeom only attempt to correct Polygons (other types should be fine)
bjorn at wololo.org
bjorn at wololo.org
Tue Aug 29 12:43:43 PDT 2017
Author: bjornharrtell
Date: 2017-08-29 12:43:43 -0700 (Tue, 29 Aug 2017)
New Revision: 15607
trunk/postgis/mvt.c
Modified: trunk/postgis/mvt.c
--- trunk/postgis/mvt.c 2017-08-29 19:09:43 UTC (rev 15606)
+++ trunk/postgis/mvt.c 2017-08-29 19:43:43 UTC (rev 15607)
@@ -629,7 +629,7 @@
* Makes best effort to keep validity. Might collapse geometry into lower
* dimension.
-LWGEOM *mvt_geom(LWGEOM *lwgeom, GBOX *gbox, uint32_t extent, uint32_t buffer,
+ LWGEOM *mvt_geom(LWGEOM *lwgeom, GBOX *gbox, uint32_t extent, uint32_t buffer,
bool clip_geom)
POSTGIS_DEBUG(2, "mvt_geom called");
@@ -679,7 +679,7 @@
lwgeom_out = lwgeom_clone_deep(lwgeom);
AFFINE affine;
- memset (&affine, 0, sizeof(affine));
+ memset(&affine, 0, sizeof(affine));
affine.afac = fx;
affine.efac = fy;
affine.ifac = 1;
@@ -700,11 +700,9 @@
if (lwgeom_out == NULL || lwgeom_is_empty(lwgeom_out))
return NULL;
- if (lwgeom_out->type != POINTTYPE && lwgeom_out->type != MULTIPOINTTYPE)
- lwgeom_out = lwgeom_make_valid(lwgeom_out);
if (lwgeom_out->type == POLYGONTYPE ||
lwgeom_out->type == MULTIPOLYGONTYPE) {
+ lwgeom_out = lwgeom_make_valid(lwgeom_out);
lwgeom_force_clockwise(lwgeom_out);
@@ -713,9 +711,9 @@
lwgeom_out = lwcollection_as_lwgeom(
lwcollection_extract(lwcoll, max_type(lwcoll)));
lwgeom_out = lwgeom_homogenize(lwgeom_out);
