[postgis-tickets] r15609 - Don't drop st_union when updating postgis extension to 2.4
Regina Obe
lr at pcorp.us
Tue Aug 29 17:25:03 PDT 2017
Author: robe
Date: 2017-08-29 17:25:02 -0700 (Tue, 29 Aug 2017)
New Revision: 15609
trunk/postgis/postgis.sql.in
trunk/postgis/postgis_drop_after.sql
Closes #3821 for PostGIS 2.4.0
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2017-08-29 19:50:38 UTC (rev 15608)
+++ trunk/postgis/postgis.sql.in 2017-08-30 00:25:02 UTC (rev 15609)
@@ -3866,7 +3866,9 @@
LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
-- Availability: 1.2.2
--- Changed: 2.4.0 marked parallel safe
+-- Changed but upgrader helper no touch: 2.4.0 marked parallel safe
+-- we don't want to force drop of this agg since its often used in views
+-- parallel handling dealt with in postgis_drop_after.sql
CREATE AGGREGATE ST_Union (geometry) (
sfunc = pgis_geometry_accum_transfn,
stype = pgis_abs,
@@ -3876,6 +3878,7 @@
finalfunc = pgis_geometry_union_finalfn
-- Changed: 2.4.0: marked parallel safe
CREATE AGGREGATE ST_Collect (geometry) (
Modified: trunk/postgis/postgis_drop_after.sql
--- trunk/postgis/postgis_drop_after.sql 2017-08-29 19:50:38 UTC (rev 15608)
+++ trunk/postgis/postgis_drop_after.sql 2017-08-30 00:25:02 UTC (rev 15609)
@@ -170,3 +170,14 @@
-- pgis_abs type was increased from 8 bytes in 2.1 to 16 bytes in 2.2
-- See #3460
UPDATE pg_type SET typlen=16 WHERE typname='pgis_abs' AND typlen=8;
+DO language 'plpgsql'
+BEGIN
+IF _postgis_scripts_pgsql_version()::integer >= 96 THEN
+-- mark ST_Union agg as parallel safe if it is not already
+ UPDATE pg_proc SET proparallel = 's'
+ WHERE oid = 'st_union(geometry)'::regprocedure AND proparallel = 'u';
+END IF;
+END;
