[postgis-tickets] [PostGIS] #3824: Doc changes from Andreas Schild via transifex
PostGIS trac at osgeo.org
Thu Aug 31 03:49:51 PDT 2017
 Reporter:  robe           |      Owner:  robe
     Type:  defect         |     Status:  new
 Priority:  high           |  Milestone:  PostGIS 2.4.0
Component:  documentation  |    Version:  2.3.x
 Keywords:                 |
 This is to accumulate all of Andreas Schild current outstanding changes
 sent via transifex messaging.
 Andreas Schild created an issue for a string in the resource
 reference_raster.xml.pot
 Andreas Schild created an issue for the string: Create a set of raster
 tiles with <xref linkend="RT_ST_MakeEmptyRaster"/>. Grid dimension is
 <varname>width</varname> & <varname>height</varname>. Tile dimension
 is <varname>tilewidth</varname> & <varname>tileheight</varname>. The
 covered georeferenced area is from upper left corner
 (<varname>upperleftx</varname>, <varname>upperlefty</varname>) to lower
 right corner (<varname>upperleftx</varname> <varname>width</varname> *
 <varname>scalex</varname>, <varname>upperlefty</varname>
 <varname>height</varname> * <varname>scaley</varname>).
 meaning of "upperleftx width"? Minus sign? : "upperleftx - width * scalex"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3824>
