[postgis-tickets] [PostGIS] #3824: Doc changes from Andreas Schild via transifex
trac at osgeo.org
Thu Aug 31 22:24:31 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.4.0
Component: documentation | Version: 2.3.x
Resolution: | Keywords:
Description changed by robe:
Old description:
> This is to accumulate all of Andreas Schild current outstanding changes
> sent via transifex messaging.
> Andreas Schild created an issue for a string in the resource
> reference_raster.xml.pot
> Andreas Schild created an issue for the string: Create a set of raster
> tiles with <xref linkend="RT_ST_MakeEmptyRaster"/>. Grid dimension is
> <varname>width</varname> & <varname>height</varname>. Tile dimension
> is <varname>tilewidth</varname> & <varname>tileheight</varname>. The
> covered georeferenced area is from upper left corner
> (<varname>upperleftx</varname>, <varname>upperlefty</varname>) to lower
> right corner (<varname>upperleftx</varname> <varname>width</varname> *
> <varname>scalex</varname>, <varname>upperlefty</varname>
> <varname>height</varname> * <varname>scaley</varname>).
> meaning of "upperleftx width"? Minus sign? : "upperleftx - width *
> scalex" ?
New description:
meaning of "upperleftx width"? Minus sign? : "upperleftx - width * scalex"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3824#comment:1>
