[postgis-tickets] r16135 - Turn off interrupt tests in configure by default.
Regina Obe lr at pcorp.us
Wed Dec 6 12:00:21 PST 2017
Author: robe
Date: 2017-12-06 12:00:21 -0800 (Wed, 06 Dec 2017)
New Revision: 16135
   branches/2.4/NEWS
   branches/2.4/configure.ac
Also added a section in configure output to note if interrupt tests are enabled or not
Closes #3827 for PostGIS 2.4.3
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS	2017-12-06 19:34:58 UTC (rev 16134)
+++ branches/2.4/NEWS	2017-12-06 20:00:21 UTC (rev 16135)
@@ -3,8 +3,9 @@
  * Bug fixes *
   - #3713, Support encodings that happen to output a '\' character
+  - #3827, Set configure default to not do interrupt testing,
+          was causing false negatives for many people
 PostGIS 2.4.2
 2017/11/15
Modified: branches/2.4/configure.ac
--- branches/2.4/configure.ac	2017-12-06 19:34:58 UTC (rev 16134)
+++ branches/2.4/configure.ac	2017-12-06 20:00:21 UTC (rev 16135)
@@ -15,6 +15,7 @@
 AC_CONFIG_AUX_DIR([build-aux])
 AC_PROG_INSTALL
 dnl Invoke libtool: we do this as it is the easiest way to find the PIC
 dnl flags required to build liblwgeom
 AC_PROG_LIBTOOL
@@ -1185,8 +1186,13 @@
                     [Disable the interrupt tests (for CI servers)])],
-if test "x$with_interrupt_tests" != "xno"; then
-    INTERRUPTTESTS="yes"
+AC_ARG_WITH([interrupt-tests],
+    [AS_HELP_STRING([--with-interrupt-tests],
+                    [Enable interrupt tests])],
+    [INTERRUPTTESTS="yes"], [])
+if test "x$with_interrupt_tests" == "xno"; then
+    INTERRUPTTESTS="no"
 fi
 AC_SUBST([INTERRUPTTESTS])
@@ -1472,6 +1478,13 @@
 AC_MSG_RESULT([  C compiler:           ${CC} ${CFLAGS}])
 AC_MSG_RESULT([  SQL preprocessor:     ${SQLPP}])
 AC_MSG_RESULT()
+AC_MSG_RESULT([ -------------- Additional Info ------------- ])
+if test "x$INTERRUPTTESTS" = "xyes"; then
+  AC_MSG_RESULT([  Interrupt Tests:   ENABLED])
+else
+  AC_MSG_RESULT([  Interrupt Tests:   DISABLED use: --with-interrupt-tests to enable])
+fi
+AC_MSG_RESULT()
 AC_MSG_RESULT([ -------------- Dependencies -------------- ])
 AC_MSG_RESULT([  GEOS config:          ${GEOSCONFIG}])
 AC_MSG_RESULT([  GEOS version:         ${GEOS_FULL_VERSION}])
