[postgis-tickets] r16173 - Fix warning when building against GEOS < 3.5
Sandro Santilli
strk at kbt.io
Wed Dec 20 11:34:43 PST 2017
Author: strk
Date: 2017-12-20 11:34:43 -0800 (Wed, 20 Dec 2017)
New Revision: 16173
trunk/liblwgeom/lwgeom_geos.c
See https://gitlab.com/postgis/postgis/-/jobs/45372613
Modified: trunk/liblwgeom/lwgeom_geos.c
--- trunk/liblwgeom/lwgeom_geos.c 2017-12-20 19:28:16 UTC (rev 16172)
+++ trunk/liblwgeom/lwgeom_geos.c 2017-12-20 19:34:43 UTC (rev 16173)
@@ -2059,6 +2059,15 @@
#endif /* POSTGIS_GEOS_VERSION < 34 */
+#if POSTGIS_GEOS_VERSION < 35
+LWGEOM* lwgeom_voronoi_diagram(const LWGEOM* g, const GBOX* env, double tolerance, int output_edges)
+ lwerror("lwgeom_voronoi_diagram: GEOS 3.5 or higher required");
+ return NULL;
+#else /* POSTGIS_GEOS_VERSION >= 35 */
static
GEOSCoordSequence* lwgeom_get_geos_coordseq_2d(const LWGEOM* g, uint32_t num_points)
@@ -2096,11 +2105,8 @@
return coords;
-LWGEOM* lwgeom_voronoi_diagram(const LWGEOM* g, const GBOX* env, double tolerance, int output_edges) {
-#if POSTGIS_GEOS_VERSION < 35
- lwerror("lwgeom_voronoi_diagram: GEOS 3.5 or higher required");
- return NULL;
-#else
uint32_t num_points = lwgeom_count_vertices(g);
LWGEOM *lwgeom_result;
char is_3d = LW_FALSE;
@@ -2156,5 +2162,6 @@
lwgeom_set_srid(lwgeom_result, srid);
return lwgeom_result;
-#endif /* POSTGIS_GEOS_VERSION < 35 */
+#endif /* POSTGIS_GEOS_VERSION >= 35 */
