[postgis-tickets] [PostGIS] #3706: Use of deprecated function
PostGIS trac at osgeo.org
Thu Dec 21 14:22:36 PST 2017
  Reporter:  postgispaul  |      Owner:  robe
      Type:  defect       |     Status:  closed
  Priority:  high         |  Milestone:  PostGIS 2.3.3
 Component:  postgis      |    Version:  2.3.x
Resolution:  worksforme   |   Keywords:
Comment (by strk):
 POSTGIS="2.4.2 r16113" PGSQL="96" (procs need upgrade for use with "100")
 The above means that the version of your PostGIS scripts
 were built for PostgreSQL 9.6 while they are being used
 in a PostgreSQL 10. The way to fix this would be to rebuild
 PostGIS against the correct PostgreSQL version and then
 force-upgrade as you mention.
 To force-upgrade, if you installed PostGIS as an extension
 you'll have to do:
  ALTER EXTENSION postgis UPDATE to 2.4.2next;
  ALTER EXTENSION postgis UPDATE to 2.4.2;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3706#comment:7>
