[postgis-tickets] [PostGIS] #3950: PostGIS trunk doesn't work against 9.5
PostGIS trac at osgeo.org
Fri Dec 22 20:36:49 PST 2017
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 2.5.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 I guess we can't use the ALLOC small sizes for 9.5
 This is showing on winnie's 9.5 and 9.4 tests
 prototypes  -c -o lwgeom_transform.o lwgeom_transform.c
 lwgeom_transform.c: In function 'AddToPROJ4SRSCache':
 lwgeom_transform.c:545:42: error: 'ALLOCSET_SMALL_SIZES' undeclared (first
 use in this function)
                                           ALLOCSET_SMALL_SIZES);
 lwgeom_transform.c:545:42: note: each undeclared identifier is reported
 only once for each function it appears in
 lwgeom_transform.c:545:42: error: too few arguments to function
 'AllocSetContextCreate'
 In file included from lwgeom_transform.c:18:0:
 E:/jenkins/postgresql/rel/pg9.5w64gcc48/include/server/utils/memutils.h:131:22:
 note: declared here
  extern MemoryContext AllocSetContextCreate(MemoryContext parent,
 Makefile:61: recipe for target 'lwgeom_transform.o' failed
 make[1]: *** [lwgeom_transform.o] Error 1
 make[1]: Leaving directory '/projects/postgis/branches/2.5/libpgcommon'
 GNUmakefile:16: recipe for target 'all' failed
 make: *** [all] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3950>
