[postgis-tickets] r16181 - Add 2.5 new / enhanced /changed functions section to docs
Regina Obe lr at pcorp.us
Fri Dec 22 11:53:17 PST 2017
Author: robe
Date: 2017-12-22 23:53:16 -0800 (Fri, 22 Dec 2017)
New Revision: 16181
   trunk/doc/xsl/postgis_aggs_mm.xml.xsl
Modified: trunk/doc/xsl/postgis_aggs_mm.xml.xsl
--- trunk/doc/xsl/postgis_aggs_mm.xml.xsl	2017-12-21 17:59:41 UTC (rev 16180)
+++ trunk/doc/xsl/postgis_aggs_mm.xml.xsl	2017-12-23 07:53:16 UTC (rev 16181)
@@ -483,7 +483,107 @@
 	   <sect1 id="NewFunctions">
 			<title>New, Enhanced or changed PostGIS Functions</title>
+            <sect2 id="NewFunctions_2_5">
+				<title>PostGIS Functions new or enhanced in 2.5</title>
+				<para>The functions given below are PostGIS functions that were added or enhanced.</para>
+                <xsl:if test="//para[contains(text(),'Availability: 2.5')]">
+				<para>Functions new in PostGIS 2.5</para>
+				<itemizedlist>
+				<!-- Pull out the purpose section for each ref entry and strip whitespace and put in a variable to be tagged unto each function comment  -->
+					<xsl:for-each select='//refentry'>
+						<xsl:sort select="refnamediv/refname"/>
+						<xsl:variable name='comment'>
+							<xsl:value-of select="normalize-space(translate(translate(refnamediv/refpurpose,'&#x0d;&#x0a;', ' '), '	', ' '))"/>
+						</xsl:variable>
+						<xsl:variable name="refid">
+							<xsl:value-of select="@id" />
+						</xsl:variable>
+						<xsl:variable name="refname">
+							<xsl:value-of select="refnamediv/refname" />
+						</xsl:variable>
+				<!-- For each section if there is note about availability in this version -->
+							<xsl:for-each select="refsection">
+								<xsl:for-each select="para | */para">
+									<xsl:choose>
+										<xsl:when test="contains(.,'Availability: 2.5')">
+											<listitem><simpara><link linkend="{$refid}"><xsl:value-of select="$refname" /></link> - <xsl:value-of select="." /><xsl:text> </xsl:text> <xsl:value-of select="$comment" /></simpara></listitem>
+										</xsl:when>
+									</xsl:choose>
+								</xsl:for-each>
+							</xsl:for-each>
+					</xsl:for-each>
+				</itemizedlist>
+                </xsl:if>
+				<xsl:if test="//para[contains(text(),'Enhanced: 2.5')]">
+				<para>Functions enhanced in PostGIS 2.5</para>
+				<itemizedlist>
+						</xsl:variable>
+						</xsl:variable>
+						</xsl:variable>
+									<xsl:choose>
+										<xsl:when test="contains(.,'Enhanced: 2.4')">
+										</xsl:when>
+									</xsl:choose>
+								</xsl:for-each>
+							</xsl:for-each>
+					</xsl:for-each>
+				</itemizedlist>
+                </xsl:if>
+				<para>Functions changed in PostGIS 2.5</para>
+				<xsl:if test="//para[contains(text(),'Changed: 2.5')]">
+				<itemizedlist>
+						</xsl:variable>
+						</xsl:variable>
+						</xsl:variable>
+									<xsl:choose>
+										<xsl:when test="contains(.,'Changed: 2.4')">
+										</xsl:when>
+									</xsl:choose>
+								</xsl:for-each>
+							</xsl:for-each>
+					</xsl:for-each>
+				</itemizedlist>
+                </xsl:if>
+			</sect2>
             <sect2 id="NewFunctions_2_4">
 				<title>PostGIS Functions new or enhanced in 2.4</title>
