[postgis-tickets] [PostGIS] #3954: Make ST_GeometricMedian aware of point weights
PostGIS trac at osgeo.org
Tue Dec 26 06:07:50 PST 2017
  Reporter:  komzpa   |      Owner:  pramsey
      Type:  patch    |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:
Changes (by komzpa):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16188" 16188]:
 #!CommitTicketReference repository="" revision="16188"
 Weight-aware ST_GeometricMedian
 Weight is to be supplied as M ordinate of individual points in MultiPoint.
 Bring lwgeom_median.c cunit test coverage to 100%.
 ST_GeometricMedian(fail_if_not_converged=false, max_iter=0)
 might give you weighted centroid, but that's not a promise.
 Closes #3954
 Closes https://github.com/postgis/postgis/pull/176
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3954#comment:1>
