[postgis-tickets] r16190 - Add 5 seconds sleep before attempt to drop regress database, to give pg time to start up in case not fully started.
Regina Obe
lr at pcorp.us
Wed Dec 27 10:37:48 PST 2017
Author: robe
Date: 2017-12-27 10:37:48 -0800 (Wed, 27 Dec 2017)
New Revision: 16190
trunk/ci/debbie/postgis_regress.sh
Closes #3962
Modified: trunk/ci/debbie/postgis_regress.sh
--- trunk/ci/debbie/postgis_regress.sh 2017-12-27 15:23:29 UTC (rev 16189)
+++ trunk/ci/debbie/postgis_regress.sh 2017-12-27 18:37:48 UTC (rev 16190)
@@ -28,6 +28,10 @@
rm -rf ${WORKSPACE}/tmp/${POSTGIS_MAJOR_VERSION}_${POSTGIS_MINOR_VERSION}_pg${PG_VER}w${OS_BUILD}
#mkdir ${WORKSPACE}/tmp/
export PGIS_REG_TMPDIR=${WORKSPACE}/tmp/${POSTGIS_MAJOR_VERSION}_${POSTGIS_MINOR_VERSION}_pg${PG_VER}w${OS_BUILD}
+#adding this sleep so postgres instance has some grace period for starting
+#otherwise the attempt to drop the database, sometimes happes when pg is in middle of start
+sleep 5
export POSTGIS_REGRESS_DB="postgis_reg" # FIXME: tweak to avoid clashes
psql -c "DROP DATABASE IF EXISTS $POSTGIS_REGRESS_DB"
