[postgis-tickets] r16201 - debug issue with winnie's build failing and make sure configure is same as regression one
Regina Obe
lr at pcorp.us
Sat Dec 30 04:41:37 PST 2017
Author: robe
Date: 2017-12-30 04:41:37 -0800 (Sat, 30 Dec 2017)
New Revision: 16201
trunk/ci/winnie/build_postgis.sh
Modified: trunk/ci/winnie/build_postgis.sh
--- trunk/ci/winnie/build_postgis.sh 2017-12-29 22:06:52 UTC (rev 16200)
+++ trunk/ci/winnie/build_postgis.sh 2017-12-30 12:41:37 UTC (rev 16201)
@@ -46,12 +46,14 @@
echo PATH BEFORE: $PATH
export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
#export PROJSO=libproj-0.dll
export POSTGIS_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
export POSTGIS_MICRO_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}
+echo POSTGIS_MICRO_VERSION: $POSTGIS_VER
if [[ "$POSTGIS_MICRO_VERSION" == *SVN* || "$POSTGIS_MICRO_VERSION" == *dev* ]] ; then
export POSTGIS_SRC=${PROJECTS}/postgis/branches/${POSTGIS_VER}
else
@@ -74,7 +76,7 @@
echo PATH AFTER: $PATH
-export PKG_CONFIG_PATH=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig;
+export PKG_CONFIG_PATH=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig
cd ${POSTGIS_SRC}
if [ -e ./GNUMakefile ]; then
@@ -97,13 +99,14 @@
if [ -n "$SFCGAL_VER" ]; then
##hard code versions of cgal etc. for now
- export CGAL_VER=4.6.1
+ export CGAL_VER=4.2
BOOST_VER=1.53.0
#BOOST_VER_WU=1_49_0
export BOOST_VER_WU=1_53_0
export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
CPPFLAGS="-I${PGPATH}/include -I${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include" \
+CFLAGS="-Wall -fno-omit-frame-pointer" \
LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/lib" ./configure \
--host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config \
--with-pgconfig=${PGPATH}/bin/pg_config \
@@ -117,9 +120,11 @@
--with-protobufdir=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE} \
--with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
--with-pcredir=${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE} \
+ --without-interrupt-tests \
--prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE}
else
@@ -131,14 +136,15 @@
--with-jsondir=${MINGPROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE} \
--with-libiconv=${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE} \
--with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
fi;
+make clean
#patch liblwgeom generated make to get rid of dynamic linking
sed -i 's/LDFLAGS += -no-undefined//g' liblwgeom/Makefile
-make uninstall
+#make uninstall
make && make install
