[postgis-tickets] r15311 - Logic for winnie to build and package with protobuf-c support
Regina Obe lr at pcorp.us
Sun Feb 12 11:15:57 PST 2017
Author: robe
Date: 2017-02-12 11:15:57 -0800 (Sun, 12 Feb 2017)
New Revision: 15311
   trunk/ci/winnie/build_postgis.sh
   trunk/ci/winnie/package_postgis.sh
   trunk/ci/winnie/regress_postgis.sh
references #3661
Modified: trunk/ci/winnie/build_postgis.sh
--- trunk/ci/winnie/build_postgis.sh	2017-02-09 08:29:55 UTC (rev 15310)
+++ trunk/ci/winnie/build_postgis.sh	2017-02-12 19:15:57 UTC (rev 15311)
@@ -18,7 +18,7 @@
 #export SFCGAL_VER=1.0.4
 #export PROJ_VER=4.8.0
+export PROTOBUF_VER=3.2.0
 export LIBXML_VER=2.7.8
 if [[ "${GCC_TYPE}" == *gcc48* ]] ; then
@@ -68,8 +68,14 @@
 #export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
 export PATH="${PGPATH}/bin:${PGPATH}/lib:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/gtk/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/xsltproc:${PATH}"
+#add protobuf
+export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
 echo PATH AFTER: $PATH
+export PKG_CONFIG_PATH=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig;
 cd ${POSTGIS_SRC}
 if [ -e ./GNUMakefile ]; then
 	make distclean
@@ -97,7 +103,7 @@
 	export BOOST_VER_WU=1_53_0
 	export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-	CPPFLAGS="-I${PGPATH}/include -I${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include" \
+CPPFLAGS="-I${PGPATH}/include -I${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include" \
 LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/lib" ./configure \
   --host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config \
   --with-pgconfig=${PGPATH}/bin/pg_config \
@@ -107,7 +113,9 @@
   --with-jsondir=${MINGPROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE} \
   --with-libiconv=${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE} \
   --with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
-  --with-gui --with-gettext=no --with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
+  --with-gui --with-gettext=no \
+  --with-protobufdir=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE} \
+  --with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
   --with-pcredir=${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}
 elif [ "$POSTGIS_MAJOR_VERSION" == "2" ] ; then
@@ -117,10 +125,11 @@
   --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/geos-config \
   --with-projdir=${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE} \
   --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/gdal-config \
 else
Modified: trunk/ci/winnie/package_postgis.sh
--- trunk/ci/winnie/package_postgis.sh	2017-02-09 08:29:55 UTC (rev 15310)
+++ trunk/ci/winnie/package_postgis.sh	2017-02-12 19:15:57 UTC (rev 15311)
@@ -16,6 +16,9 @@
 #export GCC_TYPE=
 #export SFCGAL_VER=1.1.0
 #export PCRE_VER
+export PROTOBUFC_VER=1.2.1
 	export PROJECTS=/projects
 	export MINGPROJECTS=/projects
@@ -119,6 +122,9 @@
 cp ${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin/postgisgui
 cp -p ${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin/postgisgui
+#for protobuf
+cp ${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin/libprotobuf-c-*.dll $outdir/bin
 echo "POSTGIS: ${POSTGIS_MINOR_VER} r${POSTGIS_SVN_REVISION} http://postgis.net/source" > $verfile
@@ -151,6 +157,9 @@
 	# cp -p ${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin/postgisgui
 	# cp -p ${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/*.dll $outdir/bin/postgisgui
 fi;
+echo "PROTOBUF VERSION: ${PROTOBUF_VER} https://github.com/google/protobuf" >> $verfile
+echo "PROTOBUF-C VERSION: ${PROTOBUFC_VER} https://github.com/protobuf-c/protobuf-c"  >> $verfile
 #cp ${MINGPROJECTS}/libxml/rel-libxml2-2.7.8w${OS_BUILD}/bin/*.dll  $outdir/bin/
 cp ${PGPATHEDB}/bin/libxml2-2.dll   $outdir/bin/
Modified: trunk/ci/winnie/regress_postgis.sh
--- trunk/ci/winnie/regress_postgis.sh	2017-02-09 08:29:55 UTC (rev 15310)
+++ trunk/ci/winnie/regress_postgis.sh	2017-02-12 19:15:57 UTC (rev 15311)
@@ -14,6 +14,7 @@
 export PATHOLD=$PATH
 if [ "$OS_BUILD" == "64" ] ; then
@@ -54,6 +55,10 @@
 #PATH="${MINGPROJECTS}/gettext/rel-gettext-0.18.1/bin:${MINGPROJECTS}/xsltproc:${MINGPROJECTS}/gtk/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}/include:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}/bin:${MINGPROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}/bin:${PATH}"
 PATH="${MINGPROJECTS}/xsltproc:${MINGPROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/lib:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PATH}"
+#add protobuf
 echo WORKSPACE IS $WORKSPACE
@@ -81,15 +86,13 @@
 if [ -n "$SFCGAL_VER" ]; then
 	##hard code versions of cgal etc. for now
-	export CGAL_VER=4.6.1
-	BOOST_VER=1.59.0
-	export BOOST_VER_WU=1_59_0
+	export CGAL_VER=4.2
+	BOOST_VER=1.53.0
+	#BOOST_VER_WU=1_49_0
+	export BOOST_VER_WU=1_53_0
-	#this is a major cludge but only building with pcre support if SFCGAL is built - can't figure out how to do this without passing PCRE
-	#TODO: turn back on topology regression testing once topology issues resolved
@@ -99,8 +102,10 @@
-  --with-pcredir=${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}  --without-interrupt-tests
+  --with-pcredir=${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}
@@ -109,10 +114,11 @@
 else
