[postgis-tickets] [PostGIS] #3707: Protobuf configure may need more work
trac at osgeo.org
Sun Feb 12 12:18:19 PST 2017
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Keywords: |
As noted in #3661, at least building under mingw, it was not sufficient to
specify the --with-protobufdir directory path.
I tried all sorts of permutations to figure out what's required if you are
installing in non-standard place.
It seems I had to do all the following:
1) Specify the --with-protobufdir (without this if I had protobuf and
protobufc in my path, it would pass configure, but fail at compilation
with can't find include. Though I realized now if I include include in my
path that might have done the trick.
2) Configure failed at finding PROTOBUFC, unless I also
had:
export PKG_CONFIG_PATH=path/to/protobuf/lib/pkgconfig
3) Tried as I did, I couldn't get it to work if I had protobuf and
protobufc installed in separate directories.
This could all be user error, but at lease probably should be documented
so people needing to build from source and not wanting to install in
default locations (e.g. cause they are packagers) don't run thru all this
nonsense.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3707>
