[postgis-tickets] [PostGIS] #3709: Allow signed distance for ST_Project
trac at osgeo.org
Mon Feb 13 03:58:12 PST 2017
Reporter: komzpa | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.3
Component: postgis | Version: 2.3.x
Keywords: |
ST_Project now falls with
ERROR: XX000: Distance must be between 0 and 2.00151e+07
when passed distance is negative.
for cases when you have just speed, time delta and heading and would like
to calculate position along the path line that corresponds to this point,
it breaks on negative time deltas.
This can be implemented as adding 180 degrees to the angle and taking
abs(distance).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3709>
